Replacement Calipers - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 01-07-2004, 08:14 PM
Giselberto
Does anyone know any 4-piston front brake calipers that will fit the 'Strom?
I'm going to be installing stainless steel lines, and I figured while I was doing the work, I might as well upgrade the calipers, too...if I could find something to fit on eBay.
So, what will fit? They're the same 2-piston calipers as the Bandit 600 and the Katanas, 55mm between bolt centers on the forks' brake mount tabs.
post #2 of 3 Old 01-08-2004, 10:52 PM
I'v sort of looked at the idea. You realy want to go 4 pots of a earlier GSXR ar Bandit 1200. Now I dont think any 4 pots will bolt up but just have a machinist make you addaptors, I'v done this quite a bit on some project bikes few years ago.
Vstrom sure can use a set of 4 pots thats for sure.
post #3 of 3 Old 01-13-2004, 06:21 PM
IMO the brakes are sufficient for the type of bike we ride and tires we use. HH or HH+ pads will allow you to stop with one finger as opposed to two with less applied pressure.
Four pot calipers worth a try Letsgo2up DL1000 from 2002-2012 8 07-23-2016 09:57 AM
Everything Related to Tires (Wheel removal, Repairs, DIY, ETC... Skinnifatkid Suspension and Tire Tech 36 10-28-2015 05:23 AM
4 Piston Brake Calipers Installed on ABS Bike Ruggybuggy DL650 and DL650A - 2004 to 2011 47 12-27-2012 10:25 AM
GSXR Front Calipers on a DL Dr. M V-Strom Modifications and Performance 49 04-28-2012 05:05 AM
