Semi-Automatic oiler anyone? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By PeteW
post #1 of 5 Old 10-09-2015, 12:26 AM Thread Starter
Hi,
Disregard post,
Thanks mods
Cheers,
OT
2010 Vstrom (White) 2014
2006 XVS 650 (Bobber) 2012
1993 VT250 2011
Oldteach is offline
post #2 of 5 Old 10-09-2015, 01:10 AM
p38arover's Avatar
Moved. Not ANZ-specitic.
Ron B. VK2OTC
2007 Yamaha XJR1300
RIP Bucko
1979-2008 - Riding on forever
p38arover is online now
post #3 of 5 Old 10-09-2015, 01:33 AM Thread Starter
Okay...so where are you moving it to?
Please don't forget that some Aussies may be interested, certainly not meant for the USA or Canadian folks.
So do tell?
OT
1993 VT250 2011
Oldteach is offline
post #4 of 5 Old 10-09-2015, 04:21 AM
p38arover's Avatar
Well, I thought it was obvious to where it was moved. See the top of the page.
I see you've got in a bit of a huff and taken your bat and ball and gone home. That's rather petty.
Ron B. VK2OTC
2007 Yamaha XJR1300
RIP Bucko
post #5 of 5 Old 10-09-2015, 10:32 PM
Start here
2 PCS General Primer Bulb Fuel Hose Line FOR Chainsaws Brushcutters Trimmer | eBay
Use tygon tubing, which is expensive, but doesn't go soggy after being exposed to oil. Reservour a brake fluid container, or a 250ml bottle of 2-stroke oil, use garden sprinkler fittings for the oil pickup. (There's room on top of the rear shock)
Use two of these, one BEFORE the primer to keep crap out of that, and the other low down to act as a surge chamber.
2pcs Universal Motorcycle Engine Plastic Inline Mini Fuel GAS Filter | eBay
Pre-2012 bike, drill a hold in the top of the front sprocket cover, drop the oil in there, post 2012, make up a bracket and hold the hose to the bolt that holds the front chain slider onto the swingarm, use hard plastic (garden fitting) and a heat gun and cable tie on a rubber tip.
I put the primer bulb down by my left knee, since it only needs a prod every 200k's or so that works fine.
Pete
p38arover likes this.
PeteW is offline
