Cleaning the rotor for JB Weld - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
post #1 of 18 Old 09-20-2015, 11:18 PM Thread Starter
uncaged's Avatar
What is recommended for cleaning the rotor before throwing in some JB Weld to prevent Magnet migration?
Denatured Alcohol? Naptha? brake cleaner?
uncaged
Sniper, Lover, Thug, Casual Hero, Savior of the Oppressed.
Printed on our business card as a proud member of Delta Company, 82d Combat Aviation Battalion.
2012 DL1000 Yeah Baby!
Scratch Built FXR gone
'07 Honda 919 gone
'07 Suzuki DR 650 gone
'85 Honda Sabre 45 gone
'82 Yamaha XS 650 Special II gone
'73 Honda SL350 gone
'71 Yamaha DT 250 long gone
'65 Honda CB 160 long gone
uncaged is offline
post #2 of 18 Old 09-21-2015, 08:29 AM
I have cleaned them with brake cleaner. Especially those that still have a magnet or two or three still in them, the blast from the brake cleaner tube gets into all the tight spots. I like to wipe them with alcohol after the brake cleaner.
uncaged and saxguytony like this.
realshelby is offline
post #3 of 18 Old 09-21-2015, 09:01 AM
When I reglued my magnets with JB Weld, I wanted to do ALL of them - so I had to remove a couple that were still bonded. I tried a paint stripper with a high concentration of methylene chloride and it didn't work at all. The best way to remove those stubborn magnets is with heat. Just use a propane torch and heat up the outside of the rotor next to the magnet, and the magnet will come off with ease. Then clean up everything and reapply the magnets with JB Weld - and try to get some JB Weld in the spaces between the magnets (not easy, as the epoxy is pulled towards the magnets - can make a bit of a mess).
saxguytony is offline
post #4 of 18 Old 09-21-2015, 09:33 PM Thread Starter
uncaged's Avatar
Thanks Guys,
This a preventative maintenance job. The bike has less than 700 miles onit. I am going between the magnets and installing a series regulator.
uncaged
'07 Honda 919 gone
uncaged is offline
post #5 of 18 Old 09-21-2015, 09:54 PM
What bike model and year do you have?
post #6 of 18 Old 09-22-2015, 11:09 AM Thread Starter
uncaged's Avatar
2012 dl1000
'07 Honda 919 gone
uncaged is offline
post #7 of 18 Old 09-22-2015, 11:52 AM
Adding a very small amount of JB-Weld on the magnet ends where they contact the rotor and changing to a series R/R is probably time well spent. I would also change to a Werks modified clutch at the first sign of chudder. The disparity between Vee and Wee magnet problems make me think vibration is an issue.
post #8 of 18 Old 09-22-2015, 10:09 PM Thread Starter
uncaged's Avatar
Thanks Greywolf, I also plan to paste some between the magnets to further prevent migration. Trying to build a better beast...
The Werks basket from Realshelby is on my mod list also.
uncaged
'07 Honda 919 gone
uncaged is offline
post #9 of 18 Old 09-22-2015, 11:06 PM
Don't overdo the JB-Weld. A small filet will stop the magnets from moving. Apply too much and the excess will be drawn up over the magnets as the epoxy is loaded with steel filings.
uncaged likes this.
post #10 of 18 Old 09-23-2015, 09:20 AM
If you are having issues with the JB Weld getting out of the slots or just otherwise a sloppy job, wait about 1 1/2 to 2 hours after putting it in. It is starting to become more solid about then. Very easy to shape it with a razor blade and/or remove excess from where it shouldn't be! Main thing is try to get a fairly equal amount between each magnet.
uncaged likes this.
