Anyone Running MotoLED Turn Signals? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 37 Old 08-17-2008, 02:11 PM Thread Starter
Question Anyone Running MotoLED Turn Signals?
Considering purchasing a set for both front and rear.
Who else has installed them?
Are install instructions included?
Thanks
Anderstr0m is offline
post #2 of 37 Old 08-17-2008, 02:18 PM
Bahill's Avatar
Man, I hope this doesn't break any forum rules but I asked this same question on the other VStrom user forum last March. No one had tried them so I ordered a set and did a report on the install. Check out my write up at the following:
http://11109.rapidforum.com/topic=110469558410
Hope this will help.
Bahill is offline
post #3 of 37 Old 08-17-2008, 02:43 PM Thread Starter
Excellent write up Bahill; much appreciated. I will forgo the clear housings and keep the the stock amber ones for now.
post #4 of 37 Old 08-17-2008, 02:55 PM
Bahill's Avatar
I would love to hear your thoughts when you complete the install. Also, I have never hooked up the brake light wire and I'm still curious how that works. Hope you share any info you have when you complete the install.
Bahill is offline
post #5 of 37 Old 08-17-2008, 05:36 PM Thread Starter
Was thinking about this LED tail housing to complete the set - like you said in your write up though, looks like most of the rear needs to be disassembled.
post #6 of 37 Old 08-17-2008, 06:42 PM
Bahill's Avatar
Have you seen this;
http://11109.rapidforum.com/topic=11...20tail%20light
I was thinking more along the lines of something like this but have not yet decided.
Bahill is offline
post #7 of 37 Old 08-17-2008, 07:27 PM Thread Starter
Originally Posted by Bahill View Post
I had not, thanks. Doesn't sound so bad.
I've done just bulb replacements in automotive brake housing before, and while they are bright, they don't light up the entire housing, and you kind of get a hot spot look.
Most of the LED shops now have 'wide angle' or side firing LEDs now, like this 1157, but I still think I'd rather go with the whole panel solution. I don't know; I'm kinda of waffling on the tail light setup.
It'll be a few weeks likely before I'm ready to puller the trigger; I'm working on my HID install this week.
post #8 of 37 Old 08-17-2008, 07:43 PM
Bahill's Avatar
Yes, I have seen the Super Bright LEDs and read a few post regarding them, I just don't see any led tail lights that "float my boat". Also, I have a Hyper-lite brake light already mounted so I'm not in a hurry. Until I find something I want to try I'll just be lazy for a while.
By the way, I've had my tail end assembly off and there's nothing to it. Get the rack off and then there are two fasteners, one on each side of the fender that come out then you can pull the tail assembly out enough to unplug a wiring harness and you will be holding it in your hands. That's for the DL1000, should be close for the 650.
Would like to see what you finally decide on.
Bahill is offline
post #9 of 37 Old 08-17-2008, 10:41 PM
Heavy's Avatar
Wow, over $100.00 and no power savings?
DL1000K6
Heavy is offline
post #10 of 37 Old 08-18-2008, 08:14 AM
Bahill's Avatar
You can find in the original write up a stated 40% reduction in power usage and the source of this information along with a friend of mine questioning the validity of this information. As for me I donít really know if indeed there is a power savings. I do know they are expensive but they are much more noticeable than the dismal OEM signals.
Bahill is offline
