H&B centerstand install issue - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 08-12-2008, 04:37 PM Thread Starter
I recently purchased my first bike; a brand new 2008 DL650 ABS and it currently has 300~ or so miles on it. I placed an order for a H&B centerstand (plus a few other things) from Adventure MotoStuff. After it arrived, I tried to install it following the instructions posted bu Scubadvr on vrsi (http://11109.rapidforum.com/topic=121170707212). The only difference I found is that all 4 of the spacers are the same height instead of the 2 for the smaller bolts being 2mm shorter. (The parts sheet lists them as the same piece 150.982 size 18x11x9)
The install went fine without any hiccups until the end where I noticed the foot of the centerstand on the left side comes into contact with the chain when in the up position. I pulled it apart thinking I may have made a mistake and put it together again to find the issue is still there. I have taken it off for now, but am still curious as to what the problem may be. Does anyone have any suggestions?
I did take some pics, and can post them. Unfortunately I forgot to put the camera in macro mode so they came out a little blurry. If need be I can put the stand on again and take fresh ones if it would help.
Thanks in advance all.
-pop'
popnfresh is offline
post #2 of 8 Old 08-15-2008, 08:32 AM
RichDesmond's Avatar
-pop'
I noticed the same thing on mine. Well, almost. It wasn't quite touching, but closer than I liked. I had some hard rubber laying around and cut out some disks the same diameter as the rubber stop on the H-B stand. Glued them together and and then glued them to the stop. That was enough to keep the chain out the centerstand foot, as long as I don't let the chain get loose.
Rich Desmond
RichDesmond is offline
post #3 of 8 Old 08-15-2008, 09:17 AM Thread Starter
I thought about doing that, but was concerned it would would hit the chain at some point. I took a measurement and about 4mm of the right side of the left foot comes into contact with the chain. Right now I'm tossing around the idea of returning/selling the H&B one and going with another one that might have more clearance. On that note, does anyone happen to know if the Suzuki OEM or SW-Motech centerstands have more clearance than the H&B one?
post #4 of 8 Old 08-15-2008, 09:20 AM
AppGap's Avatar
I just installed a SW stand and it has much more clearance......must be an inch or so anyway.
04 Wee with all kinds of excess crap..
AppGap is offline
post #5 of 8 Old 08-15-2008, 06:32 PM Thread Starter
I gave Adventure Moto Stuff a call and spoke with them about the clearance issue. They said that it is fairly common, and that when you put the bike in gear; the chain will tighten up and it will not be an issue. They actually went and double checked on their strom to confirm theirs to was hitting the chain. I think I may do what Rich did and keep it for now.
post #6 of 8 Old 08-15-2008, 10:47 PM
I've got 10k on the setup now, no problems. FWIW
Rich Desmond
post #7 of 8 Old 08-15-2008, 10:57 PM
Jblk9695's Avatar
Mine rubbed a bit to, but no problem so far
Jerry
Second childhood, heck, I'm still in the first. 72 going on 25
Added an 09 Yamaha FZ6 for my birthday
Sold the FZ6 and got a Triumph Tiger 800
Now have a Triumph Bonneville and an 09 Wee
Retired and lovin it
1945 Wife
Jblk9695 is offline
post #8 of 8 Old 08-15-2008, 11:32 PM Thread Starter
Thanks for the reassuring posts guys. Tomorrow morning I'll reinstall it and then begin working on installing all the other goodies I recieved in the mail :-D
