Fiamm horn WITHOUT a relay? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 08-10-2008, 11:13 PM Thread Starter
Hey all.
Was just starting to install my new Fiamm air horn. Removed the wires from the old horn, getting ready to install them to a relay. So I tried out just the stock wires on the new horn and it worked great. Loud as all hell. Now I'm wondering if I really want to go through the hassle of installing that relay, running a new wire to the battery, etc.
Has anyone tried to run a Fiamm without a relay for some time? Would like to hear what the results are.
artcore is offline
post #2 of 9 Old 08-10-2008, 11:48 PM
bald blur's Avatar
It's my understanding that the horn will work without the relay the problem is that you may burn out the wiring in the switch or elsewhere in the system.
'03 Silver 1K
bald blur is offline
post #3 of 9 Old 08-11-2008, 01:27 AM
dtalk's Avatar
It might work, but is probably drawing considerably more current than the components in that circuit were designed to sustain reliably. In particular, the horn switch might not not last long under those conditions, and it costs more than a relay.
Cheers -d
dtalk is offline
post #4 of 9 Old 08-11-2008, 02:44 AM
Mr.Metal's Avatar
As the other members have already stated, you do not want to run such a high amp device through the stock wiring. Something somewhere will most likely fry, and that would suck. Do the job right and install the relay. You want the power drawn directly from the battery (fused, of course, either inline or through a fuse block), try to avoid running any electrical farkles through the stock wiring.
2008 DL650 a.k.a. Road Warrior, member #16 of the Flat Black Club
2009 Aprilia Tuono 1000R a.k.a. Silver Thunder
Mr.Metal is offline
post #5 of 9 Old 08-11-2008, 11:20 AM Thread Starter
what rating
thanks for the replies - i will install the relay. how many amps should the inline fuse be? the manual didn't specify. and do i get the power from the battery's main terminal or is there a more convenient place?
artcore is offline
post #6 of 9 Old 08-11-2008, 11:27 AM
condensr's Avatar
Look at the maximum current rating (amperage draw) for the horn, then get the fuse that is the closest size higher. That's assuming you are using the wiring that came with the horn, or at least wiring that is the size recommended by the horn manufacturer.
Can't speak to the power tap location; haven't added any electrical goodies to this bike yet. On my old GS1000, the terminal/lug on the factory fuse box that connects to the battery is much more convenient to use than the battery terminal.
DL650K6 in Red
1981 GS1000GL
2002 Subaru Outback VDC H6
condensr is offline
post #7 of 9 Old 03-19-2009, 07:31 AM
Ecuador's Avatar
Horn
this was my question exacly !
So glad for that "search" feature.
Thanks for all the reply.
Vinny
Ecuador is offline
post #8 of 9 Old 03-19-2009, 08:05 AM
msi1259's Avatar
I realize this is an old thread, but it would be interesting for someone with a larger horn hooked up without a relay to press the flash-to-pass switch and press the horn at the same time. The Wee horn is fed from the power to the flash-to-pass switch, and (if on low beam) the above is done - two headlights will be on with both hi and low beams on, and the horn on, it would likely blow the fuse? It may even do this with the stock horn?
DL1000K5
msi1259 is offline
post #9 of 9 Old 03-19-2009, 08:38 AM
The horn is fed off the high beam fuse on both bikes, whether the high beams are actuated by the flash to pass button or the high/low switch. The low beams have a separate fuse.
