Help i bought a used corbin and it wont fit my bike - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 08-21-2015, 09:09 PM Thread Starter
Bought a used corbin that a guy took off of a 07 1000, i have a 07 650 and when i got it i cant get it to fit. Just wondered if im missing something or it just wont fit? any advice appreciated Thanks
bluecycle3 is offline
post #2 of 10 Old 08-21-2015, 09:15 PM
It will fit as good as any Corbin does. Might have to trim the front tab to clear coolant tank.
realshelby is online now
post #3 of 10 Old 08-21-2015, 09:21 PM Thread Starter
Thanks for the reply, please tell me more about trimming the tab if you would thanks again.
post #4 of 10 Old 08-21-2015, 10:05 PM
In 2007, some Wee's got coolant tank moved to the rear of the fuel tank. The two leather covered bars sticking out the front of the seat run into it. If you have a coolant tank under the rear of the fuel tank, you need to cut a little off the ends of the seat bars to clear. Also, the helmet hook wires welded to the frame may interfere with the rubber feet on the bottom of the tank and need to be cut off for the seat to fit.
post #5 of 10 Old 08-21-2015, 10:21 PM Thread Starter
ok thanks i will work on it .
post #6 of 10 Old 08-22-2015, 02:52 PM
RichDesmond's Avatar
Corbins are often a little fiddley to get lined up at first. Mine took a little adjusting (I forget exactly how) to work right.
Rich Desmond
RichDesmond is offline
post #7 of 10 Old 08-22-2015, 08:04 PM Thread Starter
well i got it to fit but cant get it to latch. more work tommorow.
post #8 of 10 Old 08-22-2015, 08:40 PM
That usually means the front bars are still too long. Also make sure you have them under rear tank mounting piece and not the tank itself.
post #9 of 10 Old 08-24-2015, 11:14 AM
If it's anything like my sargent seat, then try lifting the front of the seat straight up after it's in place. I have to do this to get the seat to slide that tiny bit forward and get the latch points to line up correctly and slide right in.
2002 DL1000: 75k miles. Bought at 50k miles.
1992 XJ600: Red, Very custom.
2002 Vespa ET4 150: The wife's ride.
Nelsonmd is offline
post #10 of 10 Old 08-25-2015, 09:29 PM
Jim12X's Avatar
This probably won't apply to you, but when I was having problems getting my seat to latch I finally discovered something I had stored under the seat was getting in the way of the plastic that hangs down to the rear of the latch. Amazingly easy to latch now that I cleared out that area.
All I want is an unfair advantage.
2011 Wee (sold), 2007 Honda Goldwing (sold), 2006 Honda CRF 250X
Jim12X is offline
