Switched relay for power farkles - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 08-09-2015, 05:23 PM Thread Starter
Dakar's Avatar
I have returned to my bike an hour after parking it to find my fog lights still on. Way too often, so I installed a switched relay. The average automotive relay can handle 40+ amps, way more than you will need. For those who don't have one, it's a relay that shuts power to accessories as the ignition is shut off. For heated gear, connect direct to battery. Very easy to do; you'll need 14 ga wire for your direct connections to the battery posts and 16 ga. wire for accessories and switched lead. The switched lead on a 2012+ DL550 is on the left inside of the fender; a brown wire goes to a connector, and from it emerges a gray wire and black/white wire. Splice into the gray wire using a snap splicer available at automotive shops. Both the relay and fuse block cost less than $10 on Amazon.
The wiring codes are marked on the relay as such:
30- power from the battery
87- power out to your fuse block
85-ground to your battery
86-coil power, i.e. power from your spliced lead
87a-power that is always on; I don't recommend unless it has very low draw, i.e. cell phone charger.
See photo
Dakar is offline
post #2 of 3 Old 08-11-2015, 07:41 AM
Motor7's Avatar
I just installed two 10W Cree LEd's on the highway bar. I might regret it, but I already had 16ga marine sheathed wire running up to my cig lighter, so I just tapped in there & put a switch on the dash.....so my lights are on the un-switched leg.
Recently I have been driving/delivering & picking up tractors for my local dealer & have started doing a walk around every time I park and prior to getting back on the road. This is not just for a straps/chain check, I have found wires dangling, and pins loose. I learned walk arounds the hard way........after looking in the mirror @ 55mph on a 3 lane interstate running though Nashville, I was rather shocked to see one of my trailers 5' angle iron loading ramps cartwheeling through the air. A roll pin had fallen out that held the 2" solid round pivot bar in place.
Anyway, it's not a bad idea to do a walk around on our bikes post & pre ride...takes a min max.
'15 DL650XT
Motor7 is online now
post #3 of 3 Old 08-17-2015, 10:21 PM
uncaged's Avatar
Not relevant to thread...
Sniper, Lover, Thug, Casual Hero, Savior of the Oppressed.
Printed on our business card as a proud member of Delta Company, 82d Combat Aviation Battalion.
2012 DL1000 Yeah Baby!
Scratch Built FXR gone
'07 Honda 919 gone
'07 Suzuki DR 650 gone
'85 Honda Sabre 45 gone
'82 Yamaha XS 650 Special II gone
'73 Honda SL350 gone
'71 Yamaha DT 250 long gone
'65 Honda CB 160 long gone
uncaged is offline
