heated handgrip, wiring question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 07-24-2008, 04:16 PM Thread Starter
I'm looking for a good place to tap in for power for heated hand grips. I see on the wiring diagram that there is supposed to be a plug already there for them but I looked all around all the wiring by the handlebars and forks and under the seat and I can't find it. Anybody know where to look for it? It's supposed to be a connector with an orange wire with a green stripe and a black wire with a white stripe
bonjour is offline
post #2 of 13 Old 07-24-2008, 04:22 PM
Colin's Avatar
It's behind the radiator. A bit difficult to get at sometimes but the task is easier if you undo the bolts and let the rad tip forward.
Colin is offline
post #3 of 13 Old 07-25-2008, 12:37 PM
Ditto on that, it's there behind the radiator with not much slack so you need to drop the radiator forward. I have taken off the side fairings and such a bunch of times for various reasons and that makes getting to it a lot easier as well.
My heated grips (Hot Grips) were done by the previous owner and he just crimped into a fused wire (not sure which one). I've left it at that and have no issues.
hbonser is offline
post #4 of 13 Old 07-25-2008, 01:31 PM
bsquarewi's Avatar
Get down on the ground on the left side of the bike, you just may be able to see the plug behind the radiator and be able to get to it without taking anything off. Some people have been lucky to have a bit more slack than others and can get to it without taking the whole bike apart. I was able to plug in an EasternBeaver HeatedGrip harness into mine with a pair of kneedlenose without having to remove anything from the bike.
_____________________________
[SIZE="1"][FONT="Comic Sans MS"] - FlatBlack 2008 DL650(ABS)
[/FONT][/SIZE]
bsquarewi is offline
post #5 of 13 Old 07-25-2008, 03:29 PM Thread Starter
Thanks gentleman, I guess I have a project for the weekend
Charlie
bonjour is offline
post #6 of 13 Old 07-25-2008, 03:48 PM
I just stuck my hand in there and felt around for it.. there is really only the one loose connector in there.
2007 Blue Wee
2005 YZ450F
2003 SV650S racebike - sold
2007 Sikk Trail MX - sold
CCS #800 - retired
http://shortcutsolutions.net
squash is offline
post #7 of 13 Old 09-22-2008, 07:29 PM
Huck369's Avatar
Anyone know where I can get a connector to plug into that connector?
I'd like to tap into it for my power outlet port for my GPS....
[B][SIZE="5"]Huck[/SIZE][/B]
2005 Suzuki 650 V-Strom (4-Sale)
1990 Honda VTR250
2006 Marshin MRF230 (4-Sale)
2005 Honda CRF250X
1983 Honda CX650 Custom
1984 Honda VT500FT Ascot
Huck369 is offline
post #8 of 13 Old 09-22-2008, 07:55 PM
Huck369's Avatar
Originally Posted by Rainier_Tom View Post
The horn wire uses the same connector:
http://www.ronayers.com/browseparts....e.ronayers.com
thanks Tom!
I'll look into getting one
1990 Honda VTR250
2005 Honda CRF250X
Huck369 is offline
post #9 of 13 Old 09-22-2008, 11:51 PM
Boondocker's Avatar
I was able to reach the connector without any disassembly, though it took about 15 minutes of concerted looking to find it in the first place. It was taped to another bundle, so I had to cut the electrical tape to free it up enough to get the necessary angle to reach it with the horn plug. Using a pair of long needle nose pliers, I was able to hold it while pressing the horn plug in.
Using this plug is really the best way to go for heated grips because it's relatively easy and the circuit is keyed, so if you forget to turn off your heated grips, they won't drain the battery. I think heated grips are wonderful. I've only recently installed mine and already used them twice. It's summertime in Vegas and believe it or not, I'm not carrying heated gloves (because I don't own a pair, but not likely to be carrying them around in the summer time if I did). So I ride up to the mountains, from 2,400 ft to 8,400 ft elevation and guess what - it's cold! Heated grips save the day because they're right there when you need them. I'm not saying they would keep your hands warmer than heated gloves, but they keep your hands a darned sight warmer than no heated gloves, no matter the season.
Uncommonly Sensible
'04 DL650 - Blue, 57,000 miles, well personalized, gone but loved
'08 WR250R - Goes anywhere
2012 Yamaha Super Ténéré - makes the DL redundant
Boondocker is offline
post #10 of 13 Old 09-23-2008, 01:17 AM
KZDon's Avatar
Down in the same area, taped to the main wire bundle, there's another unused connector, white with a black cap on it, that is a keyed power source. There's another one tucked up in the fairing, and I believe there's one near the rear of the bike.
KZDon is offline
