Murphs' Forkbrace question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 07-19-2008, 01:07 PM Thread Starter
wayner's Avatar
When you mounted the forkbrace did it look the same on both forks?
One side is even w/fork housing ridge and other is maybe 1/16" above the
ridge.
Thanks in advance
Ride Safe
Wayne
DL650
DR650
wayner is offline
post #2 of 7 Old 07-19-2008, 03:39 PM
Poser's Avatar
Mine looks quite even on both sides.
2007 DL1000 - Givi Bags and Top Case - Madstad bracket with stock shield - Zumo 550 - Murphs brace - H&B center stand - Sargent seat - Switched relay electrical harness - Power Commander III USB - Highway pegs - Driver backrest
Poser is offline
post #3 of 7 Old 07-19-2008, 05:06 PM
pinkman's Avatar
Mine also is even on both sides.
Greg "Pinkman" Pink
Leesburg, FL
K4, Flat Black Club #135
pinkman is offline
post #4 of 7 Old 07-19-2008, 08:43 PM Thread Starter
wayner's Avatar
Guess Ill give em a call Monday
Thanks
Ride Safe
Wayne
DL650
DR650
wayner is offline
post #5 of 7 Old 07-19-2008, 09:10 PM
Compared To What?'s Avatar
Have you checked to make sure your forks are in the triple trees correctly and even?
Compared To What? is offline
post #6 of 7 Old 09-16-2008, 04:12 PM
SpeedStar's Avatar
Mine are even. I wonder what you found to be the cause. Give us an update if you figured it out.
FARKLE your Strom with ORIGINAL HEADLIGHT MASKS, frame guards, triple-clamp guards, fork guards and tank guards. Check them out in the link below. Thanks, Devin.
https://stromtrooper.com/showthread.php?t=19554
SpeedStar is offline
post #7 of 7 Old 09-16-2008, 05:31 PM
ridge.
Thanks in advance
Until you tighten the center clamping bolts, you can move either side up or down a little independent of the other side.
Gramps is offline
