SW Motech Center Stand Installed! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 07-18-2008, 02:37 AM Thread Starter
Those funny Germans! I love the instruction pictures included with SW Motech products, it is as if they are saying, "Eef Zu Kant figger dis owt den you are dum kopf."
So, the string trick the get the springs on is great! One thing to note is that the top bolt on the right side is a little tricky to get in place because the exhaust makes it a tight spot. I tightened it last and recommend long hex t-wrenches if you have them. (allen wrenches)
Anyhow, i ride tomorrow and will report on my handy work! ;-)
jumar is offline
post #2 of 6 Old 07-18-2008, 10:08 AM
79SouthJim's Avatar
Yes, I just went through the headache of trying to read their instructions (or lack of) for a skid plate. I finally got it on, but would like to make a special trip to Germany to vent on their technical illustrator.
A picture is worth a thousand words. I would have liked to have seen pictures with the isometric drawing. I felt like I was supposed to be a mind reader. It would have saved me a couple of hours in my 100+ degree garage.
Jim
79SouthJim is offline
post #3 of 6 Old 07-18-2008, 10:18 AM
Ball end is needed too.
post #4 of 6 Old 07-19-2008, 03:35 AM Thread Starter
Grey, What is a ball end? Does that require special undergraments?
jumar is offline
post #5 of 6 Old 07-19-2008, 05:53 AM
Send a message via AIM to BiOg Send a message via Yahoo to BiOg
For the right side I used a 5inch and a 3 inch extension, gave me enough 'play' to get it done and torqued to spec.
Guess my box set is a bit loose
-G-
DL1000K7 Blue
BiOg is offline
post #6 of 6 Old 07-19-2008, 09:53 AM
A picture is worth ten characters. Just don't use the ball end for the final torquing.
