Busted brake lever - 2013 DL650 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 06-08-2015, 05:53 PM Thread Starter
I tipped over my 2013 DL650A Adventure and broke a short section off the front brake lever. I have been looking for a replacement and considering an upgrade while I am at it. However, most parts I have found say they fit 2011/2012. Will these levers fit my 2013?
It seems that 2012 and 2013 should be the same fit but I haven't been able to confirm it.
Also, should I just get the Barkbuster Handgaurds or are there other hand guards worth considering (i.e. Acerbis, etc)?
jcall1975 is offline
post #2 of 4 Old 06-08-2015, 07:42 PM
Rolex's Avatar
Another thing you can do is put Teflon plumbers tape under the perch, this will allow your master cylinder to spin in a crash, this will save your leaver, master cylinder and mirror in the event of a big get off
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #3 of 4 Old 06-09-2015, 09:36 AM
bwringer's Avatar
It looks like Suzuki part number 57300-44G12 interchanges with the brake lever for the 2011 and 2012 DL650 and some others.
Part number 57300-44G12 supercedes 57300-44G11 and 57300-44G10, so it will interchange with the earlier part numbers.
Assemblies where 57300-44G12 is used
2012 V-Strom (DL650A) - HANDLE LEVER
2013 DL650AL3 - HANDLE LEVER
2014 DL650A - HANDLE LEVER
2014 SFV650 - HANDLE LEVER
2014 SFV650A - HANDLE LEVER
2015 DL650A - HANDLE LEVER
Assemblies where 57300-44G11 is used
2011 V-Strom (DL650) - HANDLE LEVER (DL650 L1 E3 )
2011 V-Strom (DL650) - HANDLE LEVER (DL650 L1 E28 )
2011 V-Strom (DL650) - HANDLE LEVER (DL650 L1 E33 )
2011 V-Strom (DL650A) - HANDLE LEVER (DL650 L1 E33 )
2011 V-Strom (DL650A) - HANDLE LEVER (DL650 L1 E28 )
Assemblies where 57300-44G10 is used
2007 Bandit (GSF1250S) - HANDLE LEVER
2007 Bandit (GSF1250SA) - HANDLE LEVER
2008 GSX650F - HANDLE LEVER
2008 Bandit (GSF1250S) - HANDLE LEVER
2008 Bandit (GSF1250SA) - HANDLE LEVER
2009 GSX650F - HANDLE LEVER
2009 Bandit (GSF1250S) - HANDLE LEVER
2009 Bandit (GSF1250SA) - HANDLE LEVER
2009 Gladius (SFV650) - HANDLE LEVER
Many of these "what fits what" questions can be answered by browsing one of the online parts diagrams (I use onlinecycleparts.com -- they're local to me and the online fiche is fantastic). Many also include a way to search by part number, and the results will tell you what models the parts are used on. Suzuki's engineers are masters of parts bin engineering, so you'll normally find that a part is used for many years on many different models.
bwringer is offline
post #4 of 4 Old 06-09-2015, 11:32 AM Thread Starter
Thanks. I will definately order the OEM part. I may try an aftermarket that fits the 2012 on my 2013, as long as the vendor has a good return policy.
