DL2000 Power Commander Stock Map (picture included) - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 07-07-2008, 09:11 PM Thread Starter
Poser's Avatar
Here's the stock DL9000 map. A minus sign means less than stock fuel, no minus means more than stock. I'm so confused. I thought the poor running at low RPM was due to being overly lean. The map leads me to believe that the stock fuel injection is overly rich at low RPM. Am I missing something here?
2007 DL1000 - Givi Bags and Top Case - Madstad bracket with stock shield - Zumo 550 - Murphs brace - H&B center stand - Sargent seat - Switched relay electrical harness - Power Commander III USB - Highway pegs - Driver backrest
Poser is offline
post #2 of 8 Old 07-08-2008, 11:21 AM
Hmmmm... very, very interesting... Tuning in...
gijoecam is offline
post #3 of 8 Old 07-08-2008, 08:19 PM
Been thinking about this all afternoon... Was hoping someone more knowledgable than I would shed some light on this one...
Do you have the same data for any of the other maps available for it? Just curious how those compare....
-Joe
gijoecam is offline
post #4 of 8 Old 07-08-2008, 08:56 PM
They still tune for emissions as far as I'm concerned.....I only have some minus values in the upper rev ranges, we need no more fuel there. The best maps in my opinion come from Fuelmoto, then you can fine tune them to your desire.
post #5 of 8 Old 07-08-2008, 09:20 PM Thread Starter
Poser's Avatar
Not only does that map look wrong, it IS wrong. It did indeed make the bike run worse. I replaced it with one that looks like the one below and it works great:
Poser is offline
post #6 of 8 Old 07-08-2008, 10:32 PM
That looks pretty good....I personally would add a tad bit more fuel at position 20 for the 3750/4000 RPM range.
post #7 of 8 Old 07-09-2008, 10:44 AM
Cheff's Avatar
This map was done custom on a dyno with my '06 all stock other than K&N. It is a good map, but remember just because its perfect on my bike, does not mean it will be on others. Like Big B says, making some adjustments using this map as base you can prob get a perfect map for your bike.
Or it might run perfect with just this map
'06 DL1000 Farkled
'04 XR650L
Cheff is offline
post #8 of 8 Old 07-09-2008, 02:07 PM Thread Starter
Poser's Avatar
Since my bike is bone stock mechanically, it is an excellent match. Now, my motor acts like a big V-Twin should act. Normal cruising rpm is in the 3K range with the ability to smoothly drop down to 2.5K (or even less).
My ride to work is 17 miles on a 2 lane road with almost no passing. Traffic moves at 50-55 mph. I can now drop my bike into 5th gear and leave it there. It is quiet, smooth and relaxed.
The Power Commander adds another dimension to the V-Strom; relaxed cruising. Those who say you should keep the bike over 4K should install a PC.
Poser is offline
