Aux. light wiring options - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 24 Old 07-05-2008, 07:58 PM Thread Starter
jwt
jwt's Avatar
My 55w piaa 1100X aux lights that I'll be fork mounting just arrived, and the instructions offer 4 different wiring options for connecting the "switch power lead". Here are the listed options.
1. Connect to ignition switch positive wire. Lights will operate anytime ignition is on.
2. Connect to high beam positive wire. Lights will only operate on high beam.(I Don't like this option)
3.Connect to low beam positive wire. Lights will only operate on low beam.
4. Connect to battery or lighting coil positive. Lights will operate anytime with battery.
So, how have those of you that have wired aux lights in wired yours? I have an 07 650 if that matters. -john
"I believe the most damning thing that can be said about muslims is saying you're afraid to say anything."--Penn Jillette
Pointless Profanity Club member #10 ****face.
Best Auto/Moto Insurance | Motorcycle Protection Today | FREE Trade-In Quote
jwt is offline
post #2 of 24 Old 07-05-2008, 08:18 PM
tmcgee's Avatar
Choose option 1.
tmcgee is offline
post #3 of 24 Old 07-05-2008, 08:45 PM
The Golden Monkey's Avatar
+1 on #1. Definitely not 4.
2010 Triumph Tiger 1050se
2009 DL650A - sold
2005 DL650 - dearly departed
The Golden Monkey is offline
post #4 of 24 Old 07-05-2008, 08:59 PM
#1 and the power needs to be relay controlled. Switched power will throw the relay and the relay will connect the battery to the lights. 110W for the 2 lights will sap all the spare power available to the bike and possibly then some.
post #5 of 24 Old 07-05-2008, 10:12 PM Thread Starter
jwt
jwt's Avatar
I guess I'll go w/ #1. A relay is included in the kit. Is the ignition switch positive wire easy to locate?
jwt is offline
post #6 of 24 Old 07-05-2008, 10:23 PM
There are three popular locations, the brown wire inside the sheath running down the left side of the under seat tray, the OEM heated grip connector behind the radiator if it isn't being used, and the rear brake light switch hot lead. Both the latter two are orange green wires. They can be used without cutting and splicing anything using connectors from Eastern Beaver. http://www.easternbeaver.com/Main/Pr...tedgripadaptor http://www.easternbeaver.com/Main/Pr...l#brakeadaptor
There are lots of helpful wiring aids at the E/B site.
post #7 of 24 Old 07-05-2008, 10:35 PM Thread Starter
jwt
jwt's Avatar
Thanks for all the info. I was going to go w/ 35w piaa's but I got greedy because I really like the 1100X and they aren't available in 35W. I heard of one guy on this site having battery issues w/ 55w aux lights. Anyone running 55w lights on an 07 or down 650, or hear of anyone having juice problems by running them? The box the lights came in says v-strom 650 on it, so I'm hoping if I can keep the rpms up and am not idling in long traffic jams w/ them on I'll be ok. Also, I don't plan to attempt to run anything but the lights if they're on.
jwt is offline
post #8 of 24 Old 07-06-2008, 12:26 AM
It's a good idea for anybody pushing the envelope electrically to mount a voltmeter.
post #9 of 24 Old 07-06-2008, 05:47 AM
Stromtrooper.com Sponsor
Jim Davis's Avatar
I suggest you mount a manual on/off switch in the circuit from the ignition switched POS wire to the relay coil.
Having no way to turn the lights off could be a real bummer if you have a battery on the way out, or any other problem and have to limp home conserving juice.
Face it, no matter what wattage your lamps, at idle they'll be sucking power from the battery. You therefore might want to turn the lights off a a long red light for example, if you're working on the bike, or any other time you have the bike running but not moving.
Jim Davis, Owner, Eastern Beaver Company:
http://easternbeaver.com/ - Motorcycle Electrics: 2007 DL1000 with 16/43 gearing, Superbrace, Tokico 4 Pot fronts, BackoffXP, H4 Dual Relay Kit, PC-8 Fusepanel, 2 Powerlet Sockets, Suzuki Centerstand - 1988 Africa Twin 650, 1990 VFR 750.
Jim Davis is offline
post #10 of 24 Old 07-06-2008, 07:18 AM
tmcgee's Avatar
I solved the power problem by having a 55w driving light and a 55w fog light, each switched separately. On the other hand, I seldom ride at night.
Get yourself a voltmeter if you're going to run both 55w lights at once. It beats the hell out of pushing the bike if you kill your battery completely.
tmcgee is offline
