Stebel not loud enough? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 07-03-2008, 12:23 PM Thread Starter
ksievers's Avatar
Send a message via AIM to ksievers
I installed my Stebel horn the other day, on the available spot at the rear of the front cylinder, used a Murph wiring harness. It all works fine. BUT it doesn't seem amazingly loud to me. It is a double note, nice, but I was expecting it to be "holy s---" loud.
Is it possible to wire it or otherwise do an install that works but is not quite right so as to not get 100% of the volume?? I can't imagine that would be the case but I'm open for help.
thanks - KS.
ST1300 '08
MCL Risers, grip puppies and throttle boss, that's it. "as is" is great.
V-Strom 650 K8 (sold - great bike tho)
Flat Black #117
Professor/Musician
Wee had: SuperBrace; Sonic Springs; MadStad (MP Cycle Grand Touring); Nelson-Rigg 850's; Bestem Top Case; Grip Puppies; Kuryakin Throttle Boss; Stebel, OEM HandGuards
ksievers is offline
post #2 of 9 Old 07-03-2008, 01:07 PM
Are you sure you got the positive and negative leads on the correct connectors and did you use at least 16ga wire?
post #3 of 9 Old 07-03-2008, 01:32 PM
tmcgee's Avatar
What Pat said, plus you could always add another Stebel or two.
tmcgee is offline
post #4 of 9 Old 07-03-2008, 01:42 PM
Mr.Metal's Avatar
Were you wearing earplugs when you tested it?
2008 DL650 a.k.a. Road Warrior, member #16 of the Flat Black Club
2009 Aprilia Tuono 1000R a.k.a. Silver Thunder
Mr.Metal is offline
post #5 of 9 Old 07-03-2008, 01:48 PM Thread Starter
ksievers's Avatar
I realize as a working musician I'm 1/2 deaf but not entirely.. I used the Murph kit which is supposed to have the correct gauge wire..
It wouldn't work with the + - reversed, would it?? I guess I'll go look - to be sure.
ST1300 '08
Flat Black #117
Professor/Musician
ksievers is offline
post #6 of 9 Old 07-03-2008, 02:12 PM
Living the Stereotype
Stromin'Nroman's Avatar
What's that?
Stromin'Nroman NC28729, USA
Stromin'Nroman is offline
post #7 of 9 Old 07-03-2008, 06:10 PM
badtux's Avatar
Originally Posted by Stromin'Nroman View Post
What's that (working musician)?
I think the other word for that is "barrista" .
DL650AK8. MadStad windshield bracket, Phillips +80 H4 bulbs, Rox risers, Givi top-plate and side racks, SW-Motech center stand, Suzuki handguards, Suzuki gel seat, Rick's Shelf + Powerlet outlet, Powerlet outlet on left for heated vest, RAM mount for Zumo, Pat Walsh skidplate/engine guard, generic Hardley highway pegs, Scottoiler, Symtec grip heaters, ProGrip 714 gel grips, Rick's Mirror Relocators, National Cycle V-Stream windshield, auxiliary fuse panel under seat
badtux is offline
post #8 of 9 Old 07-05-2008, 10:49 AM
Maybe its because its covered by something there?
I have two installed, they are mounted on the crash bars 1 facing left and 1 facing right.
When I am sitting on the seat I am between both horns but they are pointing away from me, Its not that loud up on the seat.
I have 1 installed on my Burgman under the plastic in the dash. I think its all blocked up by the plastic even with all the vents and the empty steering area down below. Even one on my Wee sounds better than the one on the Burgy
Though it may be the relay because I've heard people say the relay stebel gives you sucks, maybe thats whats wrong?
Black DL1000K5 - Traded
2015 R1200GSA
Waldo is offline
post #9 of 9 Old 07-05-2008, 01:19 PM Thread Starter
ksievers's Avatar
the horn is totally in the open - I have to presume the relay and all are OK as it's all part of the "Murph's Kit." Not cheap.. could have bought all the doo-dahs myself as it's not that complicated and saved a few bucks, but with the trip to the store and yada yada it's not a bad deal to buy the kit. I swapped wires around yesterday to see if anything would make a difference, and the only difference was swapping the + and - connectors yielded a very feeble sound, so that ain't it. The wires from the original horn work in either orientation - the instructions said if you get them backwards the horn will stay on constantly with the ignition key on - but that is not the case on my bike - works the same either way.
I think it is probably working just fine - perhaps I had unrealistic expectations that it'd sound like a train coming at you.
ST1300 '08
Flat Black #117
Professor/Musician
ksievers is offline
