Clutch engages too quickly on Wee - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 07-02-2008, 12:39 AM Thread Starter
Xavier6162's Avatar
My clutch engages too quickly and so doesnít allow slippage. Which isn't a problem unless Iím trying to creep at about 5mph or starting from a complete stop (stalls the engine if Iím not paying careful attention).
Can it be adjusted for better play? And if so, How?
Xavier6162 is offline
post #2 of 5 Old 07-02-2008, 12:47 AM
The position at which the friction point occurs in the lever travel can be adjusted using the adjuster by the lever pivot. The span over which the engagement takes place cannot be adjusted. That just takes practice. I'm very happy with the clutch action on my bike compared to others I've owned.
post #3 of 5 Old 07-02-2008, 12:48 AM Thread Starter
Xavier6162's Avatar
.....and the clutch engages further out than I would prefer. It engages at about a quarter inch from full release. Very irrirating.
post #4 of 5 Old 07-02-2008, 12:50 AM Thread Starter
Xavier6162's Avatar
Thanks. I can live with and easily get use to the tight engagement, but not the engagement point. Quess I better do a better job of reading my manual.
post #5 of 5 Old 07-02-2008, 06:28 AM
Living the Stereotype
Stromin'Nroman's Avatar
Try revving the motor (to generate a gyroscopic effect), pulling the clutch in more and dragging the back brake. It should work fairly easily on this bike, especially if you maintain an upward forward gaze.
Stromin'Nroman NC28729, USA
Stromin'Nroman is offline
