cutting down aftermarket windscreens - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 06-30-2008, 07:16 PM Thread Starter
Anyone cut down their givi/calsci/m&p with decent results? I've got a brand new m&p 20" GT that is simply too tall. I'm thinking of taking off 4 inches on it, but am a little apprehensive to cut a $200 windscreen that has 20 miles on it.
And to answer the next question...I still get buffeting behind it over the stock screen. Its hot. and the transition between looking above/below the LOS really sucks.
Wish this bike worked for me...I've been dealing with the buffeting for 1500 miles and can't seem to find a happy meduim.
'07 Vstrom 650
jmo3373 is offline
post #2 of 14 Old 06-30-2008, 11:28 PM
Juan_Banjovy's Avatar
I have an M&P Cycles shorty screen that I cut down to the tops of the plastic strips on the mounts. Zero buffeting but it's a little loud on the highway. I like it for summer though, flows plenty of air. In the winter, my tall Parabellum screen goes back on.
Blue '07 DL650
Juan_Banjovy is offline
post #3 of 14 Old 06-30-2008, 11:37 PM
mhoffm's Avatar
Don't despair. Cutting a screen is easy. Just requires a jig saw with a fine blade, masking tape to protect the remaining area, some fine sand paper for the cut edge, and an hour or so. I have about the same mileage on my '07. I cut the stock tall screen to just over the mount strips as well, and I never give turbulance another thought. Really, it is the best solution. In fact, you may be able to sell the one you have and just cut the stocker if you have it still. I cut mine mounted on the bike. Here's a pic. Again, you have a great bike. Cut away, use some ear plugs, and then you can figure out your next mod. Mike
mhoffm is offline
post #4 of 14 Old 07-01-2008, 10:02 PM Thread Starter
Thanks for the positive vibes. I'm more debating on selling the windscreen outright vs hacking it up. Cutting it is the easy part. Once cut, there is no turning back.
'07 Vstrom 650
jmo3373 is offline
post #5 of 14 Old 07-01-2008, 10:49 PM
garandman's Avatar
If you mark the cut line on a Cal Sci, Mark will cut it for you no charge. They use a laser to cut the edges.
garandman is offline
post #6 of 14 Old 07-05-2008, 08:58 AM
I cut 1.5" from my CalSci screen without a problem, with a high-speed cutter. And Mark is very helpful with any simple mod you with to make.
"When the going gets weird, the weird turn pro..."
Hunter S. Thompson
Fourvalve is offline
post #7 of 14 Old 07-05-2008, 09:15 AM
garandman's Avatar
Dremel, or a jigsaw? I want to make my stock windshield into a "sport."
post #8 of 14 Old 07-05-2008, 01:24 PM
Used a jigsaw. Use tape to mark where you want to cut.
Hunter S. Thompson
post #9 of 14 Old 07-10-2008, 10:58 PM
I cut the top 2 to 3 inches off both my screens on my st1300. Both had the reverse curve on the top that (I guess) is supposed to direct the air higher over your head. My theory is that all it does is cause more buffeting and turbulence. In both cases, when I cut this portion off the top of the screen, I noted a significant improvement in airflow, with less turbulence and more stability. Cut away. If the screen is no good to you the way it is, what have you lost.
Greystrom
Greystrom is offline
post #10 of 14 Old 07-11-2008, 12:31 PM
vfrcauv's Avatar
Reading the thread this morning and decided to try cutting down my stock Suzuki windscreen 3 1/2". Took 1 hour 25 minutes. Used a B & D jig saw with a 18 tooth per inch blade and a very soft Dremel buffing wheel to finish the cut. Wanted the same radius as the top of the original wind screen. Had to extend cut lines on left & right side since top of windscreen is not as wide as area to be cut. Made template and used to draw cut lines on the masking taped area, clamped to the workbench, cut it out, buffed it, and ended up with a nice looking windscreen. Thanks for the information!
Just got back from a test ride and air flow is much smoother over helmet!
Bill
08 DL650
vfrcauv is offline
