Connectors in tail - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 05-19-2015, 07:01 PM Thread Starter
triman11427's Avatar
Connectors in tail
I'm looking to add the Backoff XP to my 2014 V2 and I see 2 connectors in the tail section. I don't know the technical names for them but 1 is a white connector and the other is mor of a yellowish white. I separated the 2 ends in the white one and the brake lights and license light still work. I've ordered the DL 1000 adaptor from Eastern Beaver so I'm sure that's plug n play. What does each connector control and can I use any of the wires as a switch for my 3CS from Eastern Beaver. If I can, what color wire would I use? Thanks and I apologize for my lack of vocabulary when describing this.
triman11427 is offline
post #2 of 5 Old 05-19-2015, 07:03 PM
Connector colors are not on the diagram. What are the wire colors?
post #3 of 5 Old 05-19-2015, 08:44 PM Thread Starter
One connector has a black with white stripe leading into it. The other has green, black/white, brown, black.
post #4 of 5 Old 05-19-2015, 08:53 PM
Black with a white stripe is ground.
Light green is right turn signal hot.
White with a black stripe is brake light hot.
Brown is tail light and license light hot.
Black is left turn signal hot.
post #5 of 5 Old 05-19-2015, 09:02 PM Thread Starter
Thanks, that will make life easier.
