Drive Chain size....why is a change needed? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 06-27-2008, 07:45 AM Thread Starter
hotshoetom's Avatar
Send a message via Yahoo to hotshoetom
Ok guys, bear with me, can anyone explain why a larger chain and/or sprocket size would be desirable? Isn't the stock chain size well suited to the bike? Or is a larger size mean longer life or less maintenance? Inquiring minds want to know....
POS Chinese scooter - glad its gone
2005 Yamaha Majesty - liked the bike hated the dealer - its gone too
2007 Suzuki Burgman 650 - totaled April 2nd, 2008
2008 wee - 2900 miles in 5 weeks...weeeeee!
"Are we really crazy to get back on one of these things after falling off and expect a different result?"
hotshoetom is offline
post #2 of 6 Old 06-27-2008, 08:04 AM
I would stick with what Suzuki put on it. Why have more rotating mass to try and get going? I see it causing more stress on the engine/gearbox and being less efficient. Just my thoughts on it.
tgore3 is offline
post #3 of 6 Old 06-27-2008, 08:31 AM
Banned
I agree. If the drive chain that is on it now is up to par for the amount of torque, changing it up to a heavier chain would only bring negatives- as mentioned; more rotating mass, less efficiency. I would suspect that cleaning the chain has more to do with longevity than the size, and that the bigger chain would go about the same duration as the smaller before needing replaced.
Trooper32 is offline
post #4 of 6 Old 06-27-2008, 10:17 AM
kenneth_moore's Avatar
It might help to detach the size of the chain with changing sprockets to effectively alter the gear ratio; they are separate issues.
In one case, the feeling is that a larger, heavier-duty chain will last longer and be less prone to break. I've never broken a chain, even on my '77 HD that used the old style, non-o-ring chains, so I wonder what prompts riders to change their chains. I'm considering changing my chain, but only because I want one that looks better, like the gold/black ones.
In the other case, a rider may find, or instance, that his bike is running too high RPMs at a given speed (or too low, for that matter). By changing the size of the sprockets, you can raise or lower the RPMs for any given speed. That is a mod I did years ago on the old HD to bring the RPMs down at highway speed. Of course, the acceleration off the line suffered a bit, it's a trade off.
Go hakafugu yourself.
kenneth_moore is offline
post #5 of 6 Old 06-27-2008, 10:45 AM
SCraig's Avatar
True, but you don't have to change chain size to change sprockets. It's a pretty common change on the 650's. I went from a 15/47 ratio to 16/47 and kept my 525 chain. A bigger chain and sprockets is just heavier.
Scott Craig - Nashville, TN
SCraig is offline
post #6 of 6 Old 10-02-2015, 01:53 AM
what did the sprocket change do to your revs at 60mph or 100kph?????
melly is offline
