3 Circuit Solution - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 2 Old 05-09-2015, 05:37 PM Thread Starter
triman11427's Avatar
3 Circuit Solution
Has anyone wired up the Eastern Beaver 3CS yet? Or a PC8? I just got a 2014 VStrom 1000 and I'm looking to see if there's a difference between the wiring of the V2 and a 2011 Wee. I want to plan out for heated grips, GPS, aux lights and battery tender. In the past I used the PC8 but I have a 3CS from another bike I might use. I remember having to tap into the brake light harness in addition to the pos and neg on the battery for some reason. Correct me if I'm wrong. If that's the case where is it suggested I tap into? Thanks
triman11427 is offline
post #2 of 2 Old 05-09-2015, 06:58 PM
ltljohn's Avatar
You need to hook to the battery and the trigger for the relay. Eastern beaver sells a harness that taps into the tail light for a trigger. I would post a link but I need to build my post count. Just go to the Eastern Beaver website and look at the V-strom specific page.
ltljohn is offline
