Can I cool more? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 19 Old 09-03-2005, 12:05 PM Thread Starter
Can I cool more?
I was thinking about adding some side panels to my radiator, of a wide angle, to get some more air into the radiator.
Um, how weird is this idea? I can't see how it would be a BAD thing (almost did it to my SV650), since it is tucked up partially in the fairing.
Might do it to the oil cooler if I can't find a short peice of pipe-wrap.
*TAG*
You're it.
2005, DL650
riff42 is offline
post #2 of 19 Old 09-03-2005, 12:32 PM
I'd ask why, the system was engineered with the knowledge where the radiator is located and the amount of air that would be flowing over it and the volume of coolant available.
There is no known issue with the bike running hot but there are a number of troubles that can crop up if a bike doesn't reach the designed operating temperture especailly on a ecm controlled fuel injected bike.
If your bike is running normally hot (4 bars) then a number of checks or inspections are in order instead of trying to cure the issue without knowing the cause.
"Travel has no longer any charm for me. I have seen all the foreign countries I want to except heaven & hell & I have only a vague curiosity about one of those."
Twain
BradM is offline
post #3 of 19 Old 09-04-2005, 08:36 AM
CDN_RN
I've been thinking about this too. My bike idles at 4 bars and the fan drops it to 3...then back to 4. Dealer says it's normal. I said no. They said yes. I said no. They called Suzuki, they said yes. I said last year it ran at 2-3, they said it's fine. I said it's not, they said it is. Let's see what the next dealer has to say.
post #4 of 19 Old 09-04-2005, 10:12 AM
Leads to several more questions then, how long does it take of idling to get to 4 bars? Extended idling of 5-10 minutes or a bit longer would be normal. In what kind of conditions does it hit 4 bars, in heavy traffic stop and go and high temps this is normal.
Is the system filled with water and coolant? With no more than 60% antifreeze, less antifreeze makes for better cooling than more. The system only holds about 4.6 pints of coolant including the reserve tank.
Has the cooling system been serviced, coolant replaced? If so was the system bleed?
Is the radiator fins clean and free of obstructions like insects, mud and othe crap?
Has the radiator cap been tested for pressure?
Has the temp sender been tested for accuracy?
The thermostat operating properly and opening when it should?
The above tests are simple tasks using a thermometer or multimeter and a pan of heated water.
And is the fan working properly? and the sender for it turning on accurate so it is coming on at the right point.
The final test involves pulling the water pump impellor and inspecting it and the bearing, much more involved the the preceding components tests and if no noise is noted or any evidence of oil in the coolant or water in the oil probably isn't indicated.
My bike with an '03 1000 with 44k miles will normally run at two bars, and in heavy traffic at slow speeds it will normally hit 4 bars but a friends '04 will run at normal and same conditions as mine at 3 bars and will go to 4 about the same time. We ran the above tests on his bike and found nothing out of specificatons so we put it down to it being the slower blue than my yellow.
Twain
BradM is offline
post #5 of 19 Old 09-04-2005, 03:27 PM
CDN_RN
I guess riding at 3 bars and idling at 4 after riding, is acceptable. I was worried that in might be a problem as the last 2 yeas I've riden at 2 bars, idled at 3. Dealer refused to look at any of the above items, and the bike is under extended warranty.
post #6 of 19 Old 09-05-2005, 12:32 AM
jackpiner57's Avatar
You really have to tell us what bike you're riding. Put it in your profile. My bike always runs at 3 bars no matter what. I was in a traffic jam in Boston on friday that made me wonder when it would go to four bars. Never did. I think 3 bars is normal for the 650 and four bars for the 1000?
"Build a man a fire and he'll be warm for the night. Set a man on fire and he'll be warm for the rest of his life." - Confuseus
jackpiner57 is offline
post #7 of 19 Old 09-05-2005, 09:24 AM
TomStromie's Avatar
The temperature gauge on my DL650 quickly goes up to 3 bars and stays there no matter what the driving conditions. Even though I live in Minnesota, we have had over 20 days of 90+ degree heat that I have commuted in this summer. I would not consider 4 bars normal unless you parked it in the sun and let it idel for an extended period of time.
TomStromie is offline
post #8 of 19 Old 09-05-2005, 02:08 PM Thread Starter
I guess I was just looking at the bike weird. While taking off the tank yesterday, I sat in front of the bike, and noticed that there really IS no blockage of the radiator from the fairing like I thought there might be. My bike runs at normal temps, I just thought it would be nice to give it more air
the oil cooler is still a different problem
*TAG*
You're it.
2005, DL650
riff42 is offline
post #9 of 19 Old 09-13-2005, 08:19 PM
senecagreen
My bike (1000) always runs at 2 bars. If I get off the highway and sit at a stoplight it will go to 3 bars and the fan will kick on and it will stay at 3 bars until I take off again and go about a half mile at 35-40mph then it will drop back down to 2 bars and stay there until I get caught at another light. I have never seen 4 bars on my bike and would feel like it was on the verge of overheating if I did.
The 650 probably does run hotter as it is working harder. I have a 04 DL1000.
post #10 of 19 Old 09-13-2005, 08:28 PM
hi senecagreen
i have an 04 dl1000 and my bike runs as yours does. it has never seen 4 bars no matter how long it idles or what tempeture it is. at 4 bars i would think it's overheating as well as it has never done this. i guess i should look in the manual and see what temp it is at 4 bars.
Kaos
Kaptain_Kaos is offline
