Lights, lights, and more lights!!! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 09-03-2005, 12:01 PM Thread Starter
Disclaimer: I am not employed or hired or anything by this company, I just really love their selection, and it is a semi-hometown biz.
That said....
Check out http://www.rallylights.com/ for Hella and Optilux lights. He also sells OEM headlight units, which rock if you like to make your own stuff, including 120, 90, and now 50mm projection headlamp units.
I did a HI/LOW combo on my SV650 (which of COURSE was stolen, and that was the ONLY thing missing when I got it back...300hr of planing and prototyping that damn enclosure...anyway), which was a big odd looking, but worked wonderful.
AND, with it being Hella, they are all DOT legal.
Just passing along some info I know you tourers would like to have.
ps: the prices are cheaper than anywhere else I found (well, at least 2 years ago when I did my headlight system)
*TAG*
You're it.
2005, DL650
riff42 is offline
post #2 of 10 Old 10-02-2005, 08:30 PM
Jambotron
I just acquired my DL650K4 and I find that the stock lights (I am assuming that the PO did not change them) are incredible! The high beams are super bright retina searing photon blasts :shock: which illuminate the road ahead as good or better than my cars. I suppose if someone were doing a rally and lots of really off-road stuff then extra lights might be required. But I am extremely pleased with the brightness of the stock headlights.
Now the rear, on the other hand...
As I always say to my friends - "You can never have too many lights!"
post #3 of 10 Old 10-09-2005, 12:33 AM
keithrj
you like the highbeams?
i've found that they're aimed a bit high (get better road illumination w/ the low beams) although with all the hills around here they are useful
post #4 of 10 Old 10-09-2005, 08:50 AM
The headlights are adjustable for both horizontal and vertical alignment, the vertical adjuster is a bolt near the 4 o'clock position and the horizontal a bolt near the 10 o'clock position using the bulb wiring plug as the center of the clock. This applies to each headlight.
"Travel has no longer any charm for me. I have seen all the foreign countries I want to except heaven & hell & I have only a vague curiosity about one of those."
Twain
BradM is offline
post #5 of 10 Old 10-13-2005, 10:52 PM Thread Starter
Oh yeah, stock is wicked!! But on some turns, I want a high side light to get the corners, and when the high is on, I want to see more of the road...
yeah, you can never have too many
*TAG*
You're it.
2005, DL650
riff42 is offline
post #6 of 10 Old 10-17-2005, 07:05 AM
Try running a set of Sylvania Silverstars. They are REALLY bright, much brighter than stock. There also companies that sell aftermarket HID kits, but they usually about $300. Oh, my headlights were adjusted way up also. When I turned my high beams on it was like I was spotting for birds in trees or something.
spongebob218 is offline
post #7 of 10 Old 10-17-2005, 02:24 PM
What Sylvania Silverstar bulb fits the DL650? Got a part number or something? :wink:
RubberDown is offline
post #8 of 10 Old 10-18-2005, 03:24 PM
keithrj
i'm not sure i need anything brighter...atleast two people a night flash their brights at me.
post #9 of 10 Old 10-19-2005, 10:12 PM
The Sylvania number is H4. Both bulbs are the same. Most auto parts stores should carry them. I got mine at Pep Boys.
post #10 of 10 Old 10-20-2005, 10:17 AM
ed-g
In response to Keithrj:
I think if people are flashing their brights at you it might be an indication that your headlights are adjusted too high. I had the same problem with my 650 when it was new - the "dipped" position was way too high and I was constantly dazzling motorists, who quite understandably thought I had left my headlights on "high".
I got my service centre to adjust it at the 600m service as I think it really should have been checked as part of the pre-delivery inspection. They begrudgingly agreed that they "might have been a little on the high side".
Hope that helps,
Ed
