Anyone add reflective tape to inside of Givi top case red lens ? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 06-20-2008, 10:30 AM Thread Starter
meanmotorscooter's Avatar
I was wondering if anyone put reflective tape behind the red lens on the back of their Givi top case. I know twisted-throttle sells a kit for $25 but I can pick up the tape myself for cheap. If you have done it what color reflective tape did you use?
meanmotorscooter is offline
post #2 of 6 Old 06-20-2008, 10:47 AM
pinkman's Avatar
I put the tape kit (Twisted Throttle) inside the lenses on my 52 liter. The tape was a white/honeycomb tape.
Greg "Pinkman" Pink
Leesburg, FL
K4, Flat Black Club #135
pinkman is offline
post #3 of 6 Old 06-20-2008, 10:51 AM
Redbeard's Avatar
I didn't do it to my top case, but I did to the two E360 side cases. I used some 3M SOLAS tape. I didn't remove the backing so it was easy to slide in behind the lens - works like a charm. It adds some reflective light, but isn't as bright as reflective tape out in the open.
I bought mine here...
http://www.sailorssolutions.com/inde...ils&Item=RT001
Good luck,
Bob S.
DL1000K6 - Gray
Only motorcycle riders understand why dogs ride with their heads out the window.
Redbeard is offline
post #4 of 6 Old 06-20-2008, 10:56 AM
MrSpock's Avatar
I bought some 3M silver reflective tape on eBay and stuck it to the stock silver-ish non-reflective film GIVI puts there at the factory. I've got V-46.
MrSpock is offline
post #5 of 6 Old 06-20-2008, 11:45 AM
Heavy's Avatar
Did the same to my V46 and E41's. Works well.
DL1000K6
Heavy is offline
post #6 of 6 Old 06-20-2008, 12:24 PM
Adventure Boy®
sandiegoland's Avatar
SOLAS (Saftey Of Life At Sea) Tape can be purchased at some boat shops. Nothing like it.
On a Shad Case under the lens:
Some over the lens as well:
sandiegoland is offline
