Installing 'Cox Racing' Radiator Guard - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 06-19-2008, 09:43 PM Thread Starter
james1300's Avatar
Talking Installing 'Cox Racing' Radiator Guard
This is a Great way to add value and prevent knocking a hole in your expensive radiator! The Guard is available from Cox Racing. http://www.coxracingroup.com/
It comes in two colors. Titanium and black. For some reason titanium is $5.00 cheaper. $64.95.
http://shopping.netsuite.com/s.nl/c....category.80/.f
This is a EZ install!
You want to AVOID THIS!
Ok the 'kit' if you want to call it that comes with the guard, some self adhesive weatherstrip bits and 2 Zip-ties...
BEFORE pic...
This pic is of the 'back-side of the guard. It mounts with the lower radiator bolt and two Zip ties, on top. Note the weatherstrip bits used to 'hold off the guard from the radiator.
The installed guard. The installation takes 15 minutes tops.
I now have installed Guards on 4 bikes. 3 Yamaha's and the Wee.
Ive never encountered a cooling problem with these guards.
james1300 is offline
post #2 of 5 Old 06-23-2008, 10:58 PM
Brandon's Avatar
Thanks for the heads up. I have been looking for a rad guard for awhile now and had been unimpressed with the others I had found. This one looks to be pretty good, so I just ordered one. The website says it fits 04-06, I have an 08, so I am taking a chance on whether it'll fit or not but I don't think it will be a problem.
08 DL650
Brandon is offline
post #3 of 5 Old 06-24-2008, 03:37 PM Thread Starter
james1300's Avatar
Mines an '07. They havent changed much with the cooling system. I think you will be OK!
post #4 of 5 Old 07-26-2008, 08:50 AM
andreas's Avatar
Radiator Guard for my 650 Wee
Did an E-bay bid for my guard. With shipping the radiator guard came to $$63.85. The seller also had a matching Oil Cooler guard for an extra $12.00. Mounting looks quite simple, existing bolts should work fine, I'll find out in a few hours. If I'm happy with my purchase I'll post some before & after pic's along with his E-bay name.
andreas is offline
post #5 of 5 Old 07-26-2008, 11:33 AM
Tollster's Avatar
I think thats the one I purchased years ago, it was black with hex holes in it. I got both as well. You will not be dissapointed, good quality and very lite. You will have it on in not time. I have had no chaffing either, but check it after the first 500 miles or so.
Tollster is offline
