Adventure MotoStuff skidplate question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 06-05-2008, 08:57 PM Thread Starter
Ted Bell's Avatar
I installed the skidplate today but the clamps that go around the crash bars are loose. I have tried loosening the bolts that attach the skidplate to the clamps and then retightened the allen screws on the clamps but they don't tighten around the crash bars. Is this normal? If not, any suggestions?
Ted Bell is offline
post #2 of 8 Old 06-05-2008, 09:05 PM
did ya
put the rubbers on??
superman is offline
post #3 of 8 Old 06-05-2008, 10:00 PM
They should be tight.
When I got my skidplate, one of my clamps was tight, the other loose. I guess they make two sizes. Sounds like they sent you the wrong one.
Email them and they'll send you the right size.
Jamie
Jamie Z is offline
post #4 of 8 Old 06-05-2008, 11:43 PM Thread Starter
Ted Bell's Avatar
Rubber pads are on. I'm going to loosen everything again tomorrow and see if shifting things around a bit helps.
Ted Bell is offline
post #5 of 8 Old 06-06-2008, 12:01 AM
wayner's Avatar
Did you order the correct front clamp for your crash bars
and if you did maybe they sent you the wrong ones.
Ride Safe
Wayne
DL650
DR650
wayner is offline
post #6 of 8 Old 06-06-2008, 02:50 AM
r.andom's Avatar
Mine are very tight so I would second the other folks if you have the rubber pieces on, you might have received the wrong size hardware... of course if you don't want to send it back you could probably stop by Home Depot and pickup some mega-thick rubber to bridge the gap :^).
r.andom is offline
post #7 of 8 Old 06-06-2008, 03:21 AM
Originally Posted by r.andom View Post
]if you don't want to send it back you could probably stop by Home Depot and pickup some mega-thick rubber to bridge the gap :^).
I didn't even send mine back. I called them. The guy asked me to read the numbers on them. He said I got the wrong part and mailed it to me.
Jamie
Jamie Z is offline
post #8 of 8 Old 06-06-2008, 08:28 AM Thread Starter
Ted Bell's Avatar
I think I'll call today -- thanks for the help!
Ted Bell is offline
