Seat lowering by remoulding - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 03-23-2015, 05:25 PM Thread Starter
Douggie's Avatar
As I'm short, the height of the seat is an important factor for me. I have the lower factory seat and lowering links. All is good when riding with a load, but I would prefer to sit lower and have the suspension higher.
I have had a suggestion that I could remould the seat using a hot air gun. I have a panel-beater who's willing to give it a go. I'm a bit concerned because of either damaging the seat beyond repair or rendering it unsafe - but only finding out in a critical situation.
Has anyone got any experience of doing this or any ideas?
Doug
There's nothing I can't do, but there's a lot I won't do.
SUZI - I'm in love with her, but I'm afraid she's taking me for a ride.
SUZI - she dumped me, I was hurt, but we're both recovering now. We'll be going out together again once we're both feeling better.
We're both better now, but with heated grips, SUZI's now hot stuff!
Alas, poor SUZI [DL650 L2A 2012 - 2015 R.I.P.], I knew her well. After being dumped a second time, I must farewell her.
I'm not flighty, but SUZI II [DL650 L5A] has now stolen my heart.
Douggie is offline
post #2 of 13 Old 03-23-2015, 06:21 PM
v-chops's Avatar
There's been heaps on seats and remodelling, try a search in the centre "search" box
done for you Suzuki V-Strom Stromtrooper.com Wee-Strom DL1000 DL650 Discussion Forum adventure rider v-strom forum V-Strom RIders International VSRI - Search Results for seat foam
07 wee with the lot (nearly)
the most important part of any trip is getting home safensound
"travel by gravel and double your map" (in memory of a great Stromtrooper. Saturn5 R.I.P.)
v-chops is offline
post #3 of 13 Old 03-23-2015, 07:16 PM
Rolex's Avatar
I have not done a Strom but I have done a few dirt bikes.
Pull the staples out at the front end of the seat, by only doing the one end the cover will go back on straight, peel the cover back then shape the foam rubber with a 4" grinder, the foam is firm enough for the grinder to easily shape it, then pull the cover back up, keep a firm grip and staple it down.
It is hard work with a manual stapler but it can be done, a electric or air powered is the way to go and working on a hot day will also help things stretch.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #4 of 13 Old 03-23-2015, 08:59 PM
v-chops's Avatar
I've "shaped" foam truck seats using an electric knife, works a treat. Even a big kitchen knife works.
I wouldn't use heat
v-chops is offline
post #5 of 13 Old 03-23-2015, 09:07 PM
I shaped my seat foam and put in a gel pad using a carpet utility knife and an electric carving knife. Took half a day. A harbor freight type staple gun is the way to go.
Cryoman is offline
post #6 of 13 Old 03-24-2015, 01:59 AM Thread Starter
Douggie's Avatar
Thanks, but Ö
Originally Posted by v-chops View Post
Thanks v-chops, but I'm not looking to reshape the foam. I'm looking to remould the plastic frame (apparently called "the seat pan"). I've already had it lowered as far as the foam will allow.
I am looking to see if anyone has attacked the seat pan with a heat gun to reshape it downwards, not necessarily make it wider, but still retain clearance for undersea componentry and retain sufficient mechanical strength to be able to carry a rider's weight under all conditions.
Doug
Douggie is offline
post #7 of 13 Old 03-24-2015, 02:59 AM
Doug
There isn't much clearance there now. Put some soft foam or plasticine under the seat in the relevant areas, go for a ride, come back and check the clearance. Just as a hint, unless you really enjoy walking you don't want to be bouncing on the battery.
Pete
PeteW is online now
post #8 of 13 Old 03-24-2015, 03:49 AM
v-chops's Avatar
I've read somewhere in these pages that someone took to the seat base with a hole saw to lower it
v-chops is offline
post #9 of 13 Old 03-24-2015, 08:30 AM
I have done a fair bit seat mod : foam shaping and shaving as well as plastic pan shaping and trimming with hot gun. I will try posting a few pics later ( they are not very good pics though) do not use hot gun on foams.
You want to lower the seat as well as making it a bit narrower where it counts.
Before you do that, try cutting seat bottom rubber on half and rear latching plate/ block rubber by 5 to 10mm.
Take off the seat cover and remove the foam to observe how the seat Pan flares out where your legs goes when putting your feet down to support the bike.
What's your inseam?
L2 Glee;
K8 Wee ABS(SOLD);
AceRider is offline
post #10 of 13 Old 03-27-2015, 06:59 PM Thread Starter
Douggie's Avatar
Duck's disease
What's your inseam?
About 29" - I am about 165 cm tall (or should that be short?).
Douggie is offline
