Garage Special Sport Windscreen - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 05-31-2008, 12:53 AM Thread Starter
sock puppet's Avatar
After returning home from a 250 mile ride, I knew it was time to start getting a little more air. I've never liked the stock windscreen and have been using the Suzuki touring screen.
I mocked-up the stock screen on the bike, then cut off as much as possible off the top. I used my Dremel tool with a cutting wheel. The plastic will melt as you cut, but it all cleans up pretty easily:
After marking up the screen in various ways trying to find a look I wanted, I settled on trimmimg the fat off the sides:
After finishing both sides, I rounded the corners a bit and cleaned up my cuts:
I then sanded the back side of the screen with a fine grit paper, cleaned with rubbing alcohol, then sprayed it with Krylon Fusion flat black paint:
It was too late when I finished to do a test ride. I'll do so tomorrow, post ride impressions, and take some better pics (it's tough to take pics of black in a garage with overhead lights.)
2006 Wee Strom: GIVI crash bars, luggage brackets with E36N side cases, E45 top case with Amotostuff mounting assembly; Murph's fork brace; DV skid plate, radiator, oil cooler guard; Hepco & Becker center stand; Zuk gel seat, hanguards and tank bra; Oxford heated grips; Garmin 2610 GPS; Fenda Extenda; Blue Sea fuse box;
2003 Ducati Monster 800Si.e with a few mods.
sock puppet is offline
post #2 of 14 Old 05-31-2008, 01:25 PM Thread Starter
Update
So I took a test ride this morning. The screen provides clean air with absolutely no buffeting up to 70 mph (and I'm sure at higher speeds.) It is *slightly* louder than when I stood up on the pegs. I'm 5'8" tall, so it should be even quieter for those who are taller. I intentionally rode without ear plugs, so I'm sure it won't even be noticeable with them in. Obviously, air flow is greatly improved, and it should prove to be a much cooler ride this summer.
Overall I'm quite please with it. I wasn't going to use the stock screen anyway, so this provided a free alternative to commercially available sport screens.
As promised, here are some better pics:
post #3 of 14 Old 06-01-2008, 07:00 PM
That's COOL!!!!! I really like the looks of that.I have been thinking of doing that myself but dont want to trash the stocker cause I might use it someday.I might get some plexiglass from home depot and try that out.Paint it gloss black and put a suzuki sticker on it.I like seeing creative things like this.We ought to have a creative section in the main headings on this sight.
tconroy is offline
post #4 of 14 Old 06-01-2008, 09:19 PM Thread Starter
I see stock windscreens pop on Ebay regularly and they usually sell cheap. Or, just cut up the one you have and worry about replacing int later.
post #5 of 14 Old 06-01-2008, 10:19 PM
Sock puppet, have you ridden the bike with the shield removed ?? If you did what where the results ??
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #6 of 14 Old 06-01-2008, 11:52 PM Thread Starter
Nope, never taken the time to ride it when I had the screen off.
post #7 of 14 Old 06-02-2008, 09:05 PM
CibbyDoc's Avatar
Looks great.....good work and very neat and tidy looking....could be a market out there?????
If you fall down...Get back up...If you cant...Call an ambulance. :sad1:
[SIZE="2"][COLOR="Navy"]08 Blue Wee, Givi E45 Top Box with black reflector kit, Givi Engine Guards, Givi Side Boxes,OEM Hand Guards, SW Motech Bash Plate, Superbrace and AMHP Headlight Protectors, fork and yoke protector as well.
CibbyDoc is offline
post #8 of 14 Old 06-02-2008, 10:08 PM
Good job!!
TC01 is offline
post #9 of 14 Old 06-03-2008, 10:22 AM Thread Starter
Thanks guys. I can't make any promises, but maybe I can find a way to trace out the screen on paper, scan it in to the computer, then post it somewhere in a printable format. Anyone know how to do this?
post #10 of 14 Old 06-03-2008, 09:09 PM
I did yesterday and it wasy great.No buffeting or head vibration at all.I had my visor down and when I turned my head it felt like someone was pushing on it.Lot of pressure at 70mph but a good flow of air.A better helmet would do wonders for me.Just take you shield off and try it.
tconroy is offline
