Rox Install Question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 05-29-2008, 06:34 PM Thread Starter
echo's Avatar
Planning on a Rox Riser install soon. Looking at the pixture of the Rox at a 45 degree angle...how do you tighten the bottom clamp bolt? It would appear the part of the Rox that holds the handlebar is going to prevent getting an allen wrench in there to tighten it...if youve installed one how did you tighten the bottom bolt?
echo is offline
post #2 of 13 Old 05-29-2008, 10:56 PM
Bimjo's Avatar
I cut the short leg off of a allen wrench and used that. Works best to tighten up the back bolt first & then the front.
Jim
Perpetual Inertia Machine
Bimjo is offline
post #3 of 13 Old 05-29-2008, 11:16 PM Thread Starter
echo's Avatar
You mean like a one inch piece of a 6mm allen wrench and turn it with a 6mm open end wrench?
echo is offline
post #4 of 13 Old 05-30-2008, 01:24 AM
AlbertaStrom's Avatar
I believe he means cut off the wrench and use the new "shorter" tool.
AlbertaStrom is offline
post #5 of 13 Old 05-30-2008, 02:01 AM
Bimjo's Avatar
^^^^Yep, that. Sorry for the confusion. Cut the short leg off & use what's left (of the original wrench) to tighten the bolt.
Jim
Bimjo is offline
post #6 of 13 Old 05-30-2008, 08:44 AM Thread Starter
echo's Avatar
Or...you could replace the lower allen bolts with hex heads bolts. Then a wrench could fit under the rox's.
echo is offline
post #7 of 13 Old 05-30-2008, 12:09 PM
Bimjo's Avatar
Doable, but you'd have to put washers or a spacer under the bolt head as it's recessed into the bar mount cap. Might cause clearance issues depending on how far back you need the bars to be.
Jim
Bimjo is offline
post #8 of 13 Old 05-30-2008, 12:29 PM
Ditto on Jim's comment (Hey Jim....here you are only 30 miles away too). I bought a cheap set of extra metric allen wrenches, used my dremel to cut off the short side wrench, then tossed the set into my tool kit after tightening them down. Would not have worked well otherwise.
StromFlyer is offline
post #9 of 13 Old 05-30-2008, 12:37 PM
sturgeon's Avatar
+1. The cut-down hex key works just fine. You only need maybe a 1/4" or so of length left on the short leg.
sturgeon is offline
post #10 of 13 Old 05-30-2008, 04:38 PM
Bimjo's Avatar
Originally Posted by StromFlyer View Post
Ditto on Jim's comment (Hey Jim....here you are only 30 miles away too).[snip]
Small world, eh?
Jim
Bimjo is offline
