Audiovox CC100 install question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 21 Old 05-28-2008, 09:50 PM Thread Starter
Canis Lupus Ridin Sicles
GrayWolf's Avatar
Send a message via Yahoo to GrayWolf Send a message via Skype™ to GrayWolf
Okay, I've got it installed. When I hit set the led lights up. When I hit resume the led lights up. When I hit the brake the led lights up. The chain doesn't bind. The vacuum is strong.
It does not work! I can reach down and pull on the cable while riding and it move freely and speeds me up.
The only thing I can think of is the brake relay I installed. The brake connection was showing 12v when depressed and .07v when it was not depressed. Because of that I put a relay in line to get that voltage down to 0. I suppose I could have installed it wrong.
Does anyone have any words of wisdom? Also if anyone knows a better relay then a $9 NAPA part I'll order that instead. Please help, I'd like to get the bike buttoned back up by next weekend.
Thanks,
-GW
GrayWolf
"I wouldn't take a million dollars for the experience, but I sure wouldn't give a red cent to go through it again" -Chester Russell
2005 DL650 "Maelstrom"
2003 KLR650 "Lou"
1978 Triumph Bonneville 750 "Boomer"
Stromtrooper Offroad Club Member #3
Blue Wee-Strom Club #69
GrayWolf is offline
post #2 of 21 Old 05-28-2008, 10:02 PM
raypope's Avatar
Send a message via Yahoo to raypope
Do you have LED brake light or OEM?
2007 Wee Strom
raypope is offline
post #3 of 21 Old 05-28-2008, 10:14 PM
Good question. The unit seeks ground through the brake light filaments. An LED brake light doesn't provide a ground connection. That's what the brake relay is for. See the diagram at http://11109.rapidforum.com/topic=109771864108 for wiring suggestions.
post #4 of 21 Old 05-28-2008, 10:16 PM Thread Starter
GrayWolf's Avatar
Great point, I do have LED taillights. I still have the stockers, I'll try swapping them.
-GW
GrayWolf
2003 KLR650 "Lou"
GrayWolf is offline
post #5 of 21 Old 05-28-2008, 10:20 PM Thread Starter
GrayWolf's Avatar
Is that some kind of standard relay? My relay only has three posts.
-GW
GrayWolf
2003 KLR650 "Lou"
GrayWolf is offline
post #6 of 21 Old 05-28-2008, 10:36 PM Thread Starter
GrayWolf's Avatar
Sho nuff!
I put the regular bulbs back and she worked.
I noticed it surged quite a bit at 40-45mph. Is that normal or do I have something still slightly out of wack?
-GW
GrayWolf
2003 KLR650 "Lou"
GrayWolf is offline
post #7 of 21 Old 05-28-2008, 10:56 PM
That's the very bottom range it works at. Mine doesn't have a problem there but it is the bleeding edge. You can use the LED brake lights if you add a relay as shown in my last link.
post #8 of 21 Old 05-29-2008, 09:40 AM Thread Starter
GrayWolf's Avatar
I don't suppose you have a part number or model for that relay? As I said the best NAPA could do for me was a three prong job that obviously didn't work.
-GW
GrayWolf
2003 KLR650 "Lou"
GrayWolf is offline
post #9 of 21 Old 05-29-2008, 03:08 PM
Send a message via AIM to coop74 Send a message via Yahoo to coop74
Wink
-GW
Now you got the bugs worked out, come on down and do mine!
Robert "Coop" Cooper
03 DL1k
00 KLR650
Alcoa, TN
coop74 is offline
post #10 of 21 Old 05-29-2008, 06:58 PM Thread Starter
GrayWolf's Avatar
Now now, you come on UP and I'll do yours. But you gotta get rid of the LED taillights or get someone to reveal the part number for the relay.
-GW
GrayWolf
2003 KLR650 "Lou"
GrayWolf is offline
