Help cutting sidetand - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 05-26-2008, 11:22 PM Thread Starter
I lowered my Wee 1 inch at the rear and raised the forks 5/8 inches, how much should I take off the sidestand to get a safe lean so the bike don't tip over? I was thinking of taking off 3/4 inch.Is that a good compromise in case I want to go back to stock links?
chiliwill is offline
post #2 of 6 Old 05-26-2008, 11:35 PM
Keep it simple and safer. Just grind a little off the sidestand stop so it will swing forward more. If you ever go back to stock height you can just add a little something to the bottom of the sidestand foot. Worked for me.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #3 of 6 Old 05-27-2008, 10:24 AM
MikeB's Avatar
Strange. I lowered the ass 1" and raised the fork tubes 1" and still have adequate lean angle for stability. Maybe I'm running more shock preload.
MikeB is offline
post #4 of 6 Old 05-27-2008, 03:09 PM
TravellingStrom's Avatar
Send a message via Skype™ to TravellingStrom
I reckon that is so, now my Elka shock is setup correctly, I now have a greater lean angle, cos I ground off some of the side stand stop after lowering the bike.
Cheers
TS
TravellingStrom is offline
post #5 of 6 Old 05-28-2008, 12:16 AM
I need to figure out a way to lengthen both my side and centerstand. Since I added the Elka and 1" raising links it is too tall for the centerstand. Any ideas?
behindbars is offline
post #6 of 6 Old 05-28-2008, 12:24 AM
Sent you a PM.
Bile650 is offline
