ProTaper bars, again - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 22 Old 05-25-2008, 08:12 PM Thread Starter
Mr.Metal's Avatar
I've read about 20 threads on aftermarket bars and I can't seem to figure something out. Ok, I'm looking for bars with less "pullback", meaning I want the ends to be more parallel to the middle of the bar than the stock bars.
Everyone raves about the ProTaper SE ATV High bars. Two times now I went to the local store and held those bars up to the stock 650 bars. Unless I'm missing something obvious, the pullback on the bars is basically identical to the stock bars.
The ProTaper site states that the SE ATV High bars have a sweep of 100mm. I believe the stock bars have a 200+ mm sweep, right? So, in theory, the ATV Highs should have a much lesser pullback. Or no?
I looked at some other ProTaper SE bars to compare. They had much less sweep back, but they were also much shorter (about half the raise), so they didn't clear the tank very well and would need risers.
So, can someone confirm that the ProTaper SE ATV High bars are basically identical to stocks in terms of pullback?
I'd like to have the stock height, I just need less pullback. Price isn't an issue, quality and comfort is
2008 DL650 a.k.a. Road Warrior, member #16 of the Flat Black Club
2009 Aprilia Tuono 1000R a.k.a. Silver Thunder
Mr.Metal is offline
post #2 of 22 Old 05-25-2008, 08:39 PM
16171
Yes, Pro-Taper ATV Highs have less pullback(period).
post #3 of 22 Old 05-25-2008, 11:10 PM Thread Starter
Mr.Metal's Avatar
I've been looking, but I haven't found any (still valid) side-by-side pictures to compare them to the stock bars. I'm either looking at the wrong bar in the store, or it's mislabeled (which, actually, may be the case). Anyone have a shot of what I should be expecting?
Thank you in advance
Mr.Metal is offline
post #4 of 22 Old 05-26-2008, 08:38 AM
16171
Hopefully you'll be able to view this link, as it has all you'll need/want to know about handlebar options.
http://11109.rapidforum.com/area=35
BTD.
post #5 of 22 Old 05-26-2008, 09:27 AM
Somewhere someone once posted that the stock bars have 200+mm of pull back. That's just wrong. I recently/am currently going through some bar swapping of my own. The stock bars only have approximately 127mm off pull back which basically equates to 1 inch more than the SE ATV High bars.
Here are the specs for the stock bars.
Pull Back=127mm
Rise=95.25mm
Height=120.65
Width=742.95mm
Clamp=177.8mm
Something that I just discovered with Renthal bars v. Pro Taper.
The Rise dimension of renthal bars is measured from the center line of the clamp area to the center line of the top bend. The height dimension is measured from the center line of the clamp area to the center line of the end of the bar.
It appears that even though pro-taper uses the term "rise" in it's demension what they are really measuring to is the height dimension as defined by renthal.
Here's a dimension legend from Renthal
Gramps is offline
post #6 of 22 Old 05-26-2008, 09:40 AM
Heavy's Avatar
...I'm looking for bars with less "pullback", meaning I want the ends to be more parallel to the middle of the bar than the stock bars....
Get yourself a set of the MSR, ATV low bars. I have the ATV high on mine and there is less pullback than the stock bars, but I wanted more height. The lows have even less pullback without being higher, and I found mine for under $15.00. They're a steel, 7/8" bar so they just bolt right into the stock clamps and the stock bar end weights work fine too.
DL1000K6
Heavy is offline
post #7 of 22 Old 05-26-2008, 09:44 AM
Highveelocity's Avatar
I just bought the MSR high bars last night, paid $28 including shipping.
'05 Silver Wee, Givi crash bars, Scotts dampener, JC top box, Battlewings, Homemade fork brace, GSXR calipers with homemade brackets. TCI Outback luggage System, Mr. Eds Moto custom seat
http://s288.photobucket.com/albums/l...ty/56%20Chevy/
Life, repression, and the pursuit of tax money
Highveelocity is offline
post #8 of 22 Old 05-26-2008, 09:51 AM
Heavy's Avatar
hmmmm...they're available from most bike shops, and usually at a better price, not that $28.00 is comparable to the $80.00 to $100.00 some guys are paying for the "designer" bars. Like I said, I picked mine up for under $15.00, I think it was $11.95, plus tax, if I remember.
DL1000K6
Heavy is offline
post #9 of 22 Old 05-26-2008, 10:24 AM
I got a set of the MSR's before I went with protaper to make sure I liked the height at sweep.
MSR's have a lot more flex noticable on rough roads...
Gramps is offline
post #10 of 22 Old 05-26-2008, 10:37 AM
Heavy's Avatar
...to help soak up the vibrations. I've had my bike fully loaded and caught it by one grip when it was going over. If the bars didn't break from that they won't break when you're pottering along on rough roads.
I understand the alu bars have more cool and cache but, let's admit it, they are expensive overkill for 99.9999% of Strom riders.
DL1000K6
Heavy is offline
