Fork oil recomend... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 08-07-2005, 10:41 PM
Motornoggin
I'm having my forks straightened after a get off a few weeks ago and the guy doing the work needs to know what fork oil I want. Since this is an opportunity to make a change, what would you guys recomend?
I'm about 250# and ride failry aggressively, but I also don't like a really harsh ride. Don't go off road much either.
post #2 of 7 Old 08-07-2005, 11:19 PM
Compared To What?'s Avatar
7.5 weight and while you have the chance change out the stock springs.
Compared To What? is offline
post #3 of 7 Old 08-08-2005, 09:03 AM
SpeedStar's Avatar
I am with C2W, we both switched to Wilbers progressive springs and 7.5wt fluid. Big improvement.
SpeedStar is offline
post #4 of 7 Old 08-08-2005, 11:48 AM
TheTwins's Avatar
What were the forks doing that you didn't like, and what are they doing after the 7.5 / wilber's modification?
TheTwins is offline
post #5 of 7 Old 08-08-2005, 12:20 PM
SpeedStar's Avatar
They were way too soft and gave a lot of brake dive. With the firmer springs and heavier fluid the ride is much better. More smooth and much less brake dive.
post #6 of 7 Old 08-09-2005, 07:47 AM
TheTwins's Avatar
Sweet. Same fork oil height, just 7.5 wt?
TheTwins is offline
post #7 of 7 Old 08-09-2005, 09:10 AM
SpeedStar's Avatar
I went with 150mm airspace when fully compressed without springs in place. That was right at 500ml per fork tube.
