Is the t/s flasher an integral part of the switch? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 05-15-2008, 10:15 AM Thread Starter
Vstromper's Avatar
I've looked the wiring diagram over till I'm cross-eyed and can't find a flasher anywhere.
I was looking to power an led circuit off the t/s switch but before the flasher. Looks like I'd have to take the switch apart to do it though.
Anybody know for sure?
Thanks
Peace carries a big gun!
www.k-diggityrides.blogspot.com
'04 1k Blue
Vstromper is offline
post #2 of 7 Old 05-15-2008, 10:57 AM
The flasher is integrated into a module also containing the side stand safety switch relay. See items 7 and 8 in the fuse box area of the wiring diagram.
post #3 of 7 Old 05-15-2008, 11:17 AM Thread Starter
Vstromper's Avatar
I guess I'm looking at a different (wrong?) wiring diagram. Or are the wee and vee diffierent here too?
'04 1k Blue
post #4 of 7 Old 05-15-2008, 11:35 AM Thread Starter
Vstromper's Avatar
'04 1k Blue
post #5 of 7 Old 05-15-2008, 11:56 AM
Ya got me. I was looking at the wee diagram. You have the sidestand relay circled which is inside the module along with the flasher. The contacts to the immediate right of it are the flasher contacts. You can trace the Lbl wire from there to the turn signal switch. O/G is the hot supply to the flasher.
post #6 of 7 Old 05-15-2008, 12:39 PM Thread Starter
Vstromper's Avatar
That's the way I read it. It looks like the switch closes the circuit after the current passes through the flasher. But the O/G is hot all the time (with iginition switch on) so there is nothing that provides constant (unflashed) voltage only when the turn signal switch is closed.
Too bad!
Back to the drawing board.
'04 1k Blue
post #7 of 7 Old 05-15-2008, 02:05 PM
Yep. That's how it works. You could bypass the OEM flasher and install your own where you need it but you'd have to make sure the hazard flashers would work right. http://11109.rapidforum.com/topic=110469136260 may be interesting.
