Storage Tube ? and Topcase Light ? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 16 Old 05-11-2008, 09:18 PM Thread Starter
Where are you guys finding the black ABS tube and the caps? I went to Homedepot and Lowes, neither had that stuff..only the white pvc stuff. I'll use that if it comes to it, but I'd rather go with something that is already black.
I bought a Bestem topcase with the led lights pre-installed. Am wondering how the best and easiest way to splice that into my brake lights will be. Or do I even need to splice my brake line?
Thanks in Advanced!
[CENTER]Member 0017 of the Official Flat Black Club - 08 Matte Black Strom RIP 3/08 - valentines day 09
3/09-Current - Drk Silver 07 weeStrom Loaded [/CENTER]
code is offline
post #2 of 16 Old 05-11-2008, 10:35 PM
ABS is not allowed by code in some areas. Black Krylon fusion paint works nicely on PVC.
post #3 of 16 Old 05-12-2008, 10:26 AM
Tollster's Avatar
I used 4" Schedule 40 white. with sewer cap and collar. I also purchased 3 end caps. 1 for the other end of the tube, the other 2 where cut. I cut off the "Dome" portion, then split the remaining collars in half. This was then glued to the tube to build up the outer diameter of the 4" PVC tube, adjacent to the end cap and sewer collar. I then sanded these collars down to match the "Ovality" of my fake exhaust and to blend all the seems for a finished look.
After sanding I primed with flat black Krylon, then painted. Look for paint that is compatable with plastics.
I used nylon spacers for the mounting, these where cut at an angle so I could roll the tube to match the angle of the subframe. It took some time, but I was able to "roll the tube" into the direction I was hoping to get. One half of the angled nylon spacer went on the outside of the tube, the other half on the inside with fender washers and lock nuts. The two angles of the split nylon spacers where matched and sandwitched the tube inbetween, this allowed me to roll the tube to my desided angle.
Tollster is offline
post #4 of 16 Old 05-12-2008, 11:33 AM
:new_worthless:
post #5 of 16 Old 05-12-2008, 01:23 PM
roger123's Avatar
I could only get white here in VB. I just painted it black.
Roger ('14 Tenere ES, COG 5903)
roger123 is offline
post #6 of 16 Old 08-27-2008, 07:52 PM
ksievers's Avatar
Send a message via AIM to ksievers
what about the "how to" for the wiring??? thanks -
ST1300 '08
MCL Risers, grip puppies and throttle boss, that's it. "as is" is great.
V-Strom 650 K8 (sold - great bike tho)
Flat Black #117
Professor/Musician
Wee had: SuperBrace; Sonic Springs; MadStad (MP Cycle Grand Touring); Nelson-Rigg 850's; Bestem Top Case; Grip Puppies; Kuryakin Throttle Boss; Stebel, OEM HandGuards
ksievers is offline
post #7 of 16 Old 08-27-2008, 08:44 PM
Bahill's Avatar
Check out this thread:
https://www.stromtrooper.com/forums/s...ad.php?t=25471
Bahill is offline
post #8 of 16 Old 08-27-2008, 09:13 PM
Originally Posted by Bahill View Post
Too small for me. I also live in an area where ABS is not available. Krylon paint for plastics works fine on PVC.
post #9 of 16 Old 08-28-2008, 03:39 PM
scrminbanshee's Avatar
hey grey wolf can you post a pic frombehind thanks
scrminbanshee is offline
post #10 of 16 Old 08-28-2008, 06:53 PM
I hope you mean the bike's behind.
