Will Heated Grip drain the battery¯.? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 05-10-2008, 01:41 AM Thread Starter
Xavier6162's Avatar
Will Heated Grip drain the battery….?
….if you had left the controller in the “ON (Hi or Low)” position, key still in the ignition but in the off position.
Xavier6162 is offline
post #2 of 11 Old 05-10-2008, 01:58 AM
If the grips are wired properly, they will be off when the ignition is off. Wiring directly to the battery would be improper wiring and drain the battery.
post #3 of 11 Old 05-10-2008, 02:54 AM Thread Starter
Xavier6162's Avatar
Thanks. I was on Easter Beaver’s web sit and found two ways of mounting the grips…electrical wise.
They the connected specially for the VStrom that plugs directly into the stock heated grip socket….this ($7.95)…
or by way of the battery through a relay ($21.95)……
Just wonder why are there two methods and which is best.
post #4 of 11 Old 05-10-2008, 06:30 AM
Heavy's Avatar
They both accomplish the same thing. That is having the heated grips switched by the ignition. Turn off the ignition, turn off the grips.
The connector for the first one can be difficult to find, its behind the top of the radiator, but it simplifies your wiring.
With the second one you have to find the switched power source, that triggers the relay, which energizes the heated grip circuit. It gives you freedom to choose a more accessible wire but it also means you're going to have to break into, and reseal one of the wires in the harness.
Best choice is your call. I used the OEM heated grip wires to trigger a relay that controls an auxilliary fuse block.
DL1000K6
Heavy is offline
post #5 of 11 Old 05-10-2008, 10:56 AM
My Oxfords wire directly to the battery, that is what they recommend. They will shut off if you leave them on, when the battery reaches 11.5 volts.
post #6 of 11 Old 05-10-2008, 11:57 AM Thread Starter
Xavier6162's Avatar
But what should I do if I need to run three or more other powered items to the battery. I can’t see having multiple lines attached to the negative and positive battery terminals. What a mess.
As you can tell, I need help before I get myself into a lot of trouble.
post #7 of 11 Old 05-10-2008, 01:43 PM
If I were you, I'd look at the AP-2 kit at http://www.easternbeaver.com/Main/Pr...om/vstrom.html
post #8 of 11 Old 05-10-2008, 02:02 PM
You can certainly run directly from the battery, however it is probubly a better idea to set up a secondary (switched) fuse block like the AP-1 or AP-2, or Blue Seas as mentioned above. There are many threads here which already address the how-to's and why's on this topic. if the information found here is not enough go to twisted throttle or just google it. Here is one thread ( http://11109.rapidforum.com/topic=110272616860 ) but most folks just seem to mount the secondary fuse block in the under seat tray.
Good luck
dakarrider is offline
post #9 of 11 Old 05-10-2008, 06:46 PM
Heavy's Avatar
Yup, an aux fuse block will make life easier. I used a Blue Seas myself...
DL1000K6
Heavy is offline
post #10 of 11 Old 05-10-2008, 10:13 PM
dtaylor's Avatar
This thread has a few different 'trooper setups:
https://stromtrooper.com/showthread.php?t=19204
dtaylor is offline
