FI light comes on. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 05-09-2008, 01:46 AM Thread Starter
FI light comes on.
Slight problem and no I didn't do a search. Always ask the wrong question anyway. Lately whenever I start the Wee the FI light comes on. Restarting the bike seems to fix it. I know this has come up before but can't remember the solution for a permanent fix. Anybody remember ??
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #2 of 14 Old 05-09-2008, 01:59 AM
silverstrom's Avatar
Do you mean it stays on while the bike is running and won't go away unless you shut the bike off and restart it?
SS
DL650K7
1985 RZ500
1986 NS400R HRC
1987 RG250
1987 TZR 250
1988 RGV 250
1989 RZ 350 F2
1990 RZ 350 N2
silverstrom is offline
post #3 of 14 Old 05-09-2008, 06:33 PM Thread Starter
Yup, that's what I meant to say. Bike doesn't run any different than it's usual good, well mannered self.
05 / 650 in blue
75/Suzuki 125 RV
post #4 of 14 Old 05-09-2008, 07:51 PM
Check for a fault code by putting the bike in dealer mode. http://perljam.net/motorcycle/dl650/dealer-mode/ https://www.stromtrooper.com/forums/s...ead.php?t=4070
http://cdross.ca/V-Strom/Vtech.htm http://soconfused.wordpress.com/ The bike might seem to run okay but some component is probably running in default mode rather than optimum.
post #5 of 14 Old 05-09-2008, 09:26 PM Thread Starter
Thanks grEywolf. Will be looking under the hood very soon. Will let you know what I find. Although I think I know what it is. Will know if my suspicion is correct tomorrow.
05 / 650 in blue
75/Suzuki 125 RV
post #6 of 14 Old 05-09-2008, 11:01 PM
larolco's Avatar
Hmmm...
This sounds suspiciously like an attempt to avoid riding in the rain tomorrow.
DRZ400SK17
larolco is online now
post #7 of 14 Old 05-10-2008, 04:35 AM Thread Starter
Originally Posted by larolco View Post
Hmmm...
No way. Just heading to my pillow and the alarm is set.
05 / 650 in blue
75/Suzuki 125 RV
post #8 of 14 Old 05-10-2008, 06:33 AM
Heavy's Avatar
...to the Batcave...
DL1000K6
Heavy is offline
post #9 of 14 Old 05-10-2008, 08:53 AM Thread Starter
Okay, I am up and partially awake now. Coffee and sum foood and then The Bat Cave. BRRRRRR. Cold wet looks like fun.
05 / 650 in blue
75/Suzuki 125 RV
post #10 of 14 Old 05-14-2008, 10:25 PM Thread Starter
Okay, I lifted the hood and peered inside. Found the dealer plug and played "What's My Code". C 28 is the STVA (secondary throttle valve actuator). What does this mean to the simple minded folks with no real knowledge and experience with FI on these bikes.
I am hoping this is just an issue of the actuator hanging up a little after no riding for a couple days and then freeing up after the bike is started/stopped a couple times when I first go for a ride. The FI light does not come back on after the initial sequence of start/stop/start and everythings seems to be working normal for the rest of the day whether or not I stop for a short time or just ride for a couple hours.
I now leave my Fate in the hands of those more experienced in these matters. Thanks in advance for all help and support.
05 / 650 in blue
75/Suzuki 125 RV
