Really Dumb PC-8 Question! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 12-31-2014, 10:32 PM Thread Starter
Dave.A's Avatar
G'day all,
I've got the Eastern Beaver PC-8 mounted and ready to go, although I haven't installed the main fuse as yet.
How do I actually install my circuits? At which point in a circuit is the wiring actually routed through the PC-8?
To use a very simple illustration, if I want to mount a couple of CREE LED's as Daytime Running Lights (e.g. They'll come on automatically whenever the ignition is on), what would the wiring look like? Do I simply run the positive wire to the positive side of the PC-8 and the negative to the negative side (on the switched side of the PC-8 obviously)?
In a more complex circuit such as the one for the Stebel Nautilus horn, where in that circuit would the PC-8 come into play?
I guess where I'm getting confused is that the PC-8 already has connections to the positive & negative battery terminals and I'm struggling to see why I have to connect both sides..... I get that the power lead for the accessory goes to the positive side, but can't work out where the negative lead goes, given that the PC-8 is already connected to the negative side
That's why the title says "Really Dumb Question...."
[SIZE="2"][B]Cheers!
Dave.A[/B]
[B]2015 DL1000A in [COLOR=RED]Candy Daring Red[/COLOR]
[COLOR=BLUE]You can [I]NEVER[/I] have [U]too many[/U] Farkles!!![/B][/COLOR][/SIZE]
Dave.A is offline
post #2 of 14 Old 12-31-2014, 11:33 PM
The PC8 has positive and negative connections because any electrical device needs both to create a circuit. In any equipment diagram that shows the equipment connected to a battery, take the two battery leads and connect them to the PC8 instead. The difference is the PC8 includes a fuse so the fuse on the wire to the positive battery lead in the equipment diagram is not needed. Just put a fuse of the same value in thr PC8. It's called a circuit because it is a loop, like a circuit around a race track. Power goes from positive to the load, like your lights or horn, and returns to the negative. Remove either and the circuit is defeated and power does not flow just like racers cannot race if there is a break in the circuit they are running.
post #3 of 14 Old 01-02-2015, 06:07 PM Thread Starter
Dave.A's Avatar
Thanks Greywolf - that clears it up nicely.
I think my confusion was arising because I wasn't sure which part of the circuit needed to pass through the PC-8. Now I know it's the "power" leg.
If I have a simple circuit for low-powered devices, such as USB outlets to charge a phone/GPS or some LED lights (basically devices that don't require a relay), and I want the ability to turn said circuit on/off, can the switch be placed anywhere in the circuit? I guess the only proviso would be that it be capable of handling the current in the circuit?
On a high-power circuit that is triggered via a relay, where would the on/off switch go? On the circuit that actually causes the relay to switch on?
Thanks for your outstanding assistance!
Dave.A[/B]
Dave.A is offline
post #4 of 14 Old 01-02-2015, 06:49 PM
The switch should be on the positive side of the power circuit between the PC8 and the load. If a relay is used, the switch should be on the wire feeding the positive trigger wire to the relay so the relay shuts off when the switch is off.
post #5 of 14 Old 01-03-2015, 10:36 AM
bmwlarry's Avatar
Dave.A
I feel your pain! I think I am getting the hang of understanding some of this electrical stuff - Thanks to Greywolf!. It is certainly very confusing when you came with no electrical experience as I did. Hang in there!! and thanks Greywolf our savior!!
2013 Yamaha WR250R
2009 V-Strom 650DL-ABS
2015 Can Am Spyder RTS LTD SE6
2011 Can Am Spyder RT Limited - Sold
2010 Aspen Sentry Camping Trailer
2003 BMW K1200LT - Sold
2001 BMW K1200LT - Sold
2001 Honda 750 Nighthawk - Sold
1997 Honda 750 Nighthawk - Sold
bmwlarry is offline
post #6 of 14 Old 01-03-2015, 11:05 AM
Dabble in 12VDC two rail model railroading for a while. It will teach you circuit theory. So will high school physics.
post #7 of 14 Old 01-03-2015, 06:28 PM
bmwlarry's Avatar
I don't remember if I was ever in high school!!
2013 Yamaha WR250R
bmwlarry is offline
post #8 of 14 Old 01-03-2015, 08:12 PM Thread Starter
Dave.A's Avatar
Yeah, High School was a long, long time ago!
I think I have a fairly good basic understanding of electrics.... it's just the PC-8 & how it fits into the circuit that threw me a bit!
Dave.A is offline
post #9 of 14 Old 01-09-2015, 10:14 AM
TOScootz's Avatar
I'm going to add that you HAVE to run a negative wire back to the PC8. You can't ground (negative) to the bike's frame like you can in a car. Because the V-Strom uses aluminium and steel frames bolted together, current through the frame, combined with a bit of dirty water, would quickly damage the frame junctions. So, you need to run TWO wires to everything.
TOScootz is offline
post #10 of 14 Old 05-10-2015, 08:57 PM
wackokid's Avatar
Since this is PC-8 oriented, I was thinking of getting one of these to mount up on a 2002 DL1000. I need to clean up some wiring that the PO has installed and most of it works ago but it does look like a start of a birds nest. I was curious if anyone has mounted the PC-8 up under the fairing or is there any cautionary comments someone might have in regards to doing so??
wackokid is offline
