Stock Grip Removal - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 05-07-2008, 12:36 PM Thread Starter
Xavier6162's Avatar
Stock Grip Removal
Ok, I’ll admit it. I’m an idiot. I’ve tried the search function. But I can’t figure out how to do a search for multiple words like, “Handgrip Removal”.
So…how do you remove the stock grips without using an air compressor? I want to install a Symtec grip heated kit… which I also don’t know how to do.
Would Hot Grips be a better option?
Xavier6162 is offline
post #2 of 12 Old 05-07-2008, 12:51 PM
Forum Admin
fatalerror's Avatar
Location: South West Florida, previously, South Africa.
If you are not going to use the stock grips again, just cut them down the middle lengthwise with a box cutter and peel them of.
fatalerror is offline
post #3 of 12 Old 05-07-2008, 01:25 PM
Crazy Old Guy
fastwally's Avatar
Slip a long thin screwdriver under the grip all the way to the other end. Pull the screwdriver up a little and squirt some WD40 under the grip. Pull the screwdriver around the handlebar and slide the grip off. You can put it back on the same way and the glue will reset when it dries.
It's more fun to ride a slow bike fast than to ride a fast bike slow.
K7abs
fastwally is offline
post #4 of 12 Old 05-07-2008, 01:35 PM
There is a ridge all the way around the end of the throttle tube. Make sure to pry up the end enough to pass over it.
post #5 of 12 Old 05-07-2008, 03:21 PM
silverstrom's Avatar
I just took the grips off my 650 yesterday. On the clutch side I slid a thin screwdriver under the grip and then rotated it completely around the bar. This separated the glue from the grip and I was able to twist the grip off pretty easy. On the throttle side I first pulled the grip off off the inboard flange and then slid the same the screwdriver under the grip, pryed up a little and sprayed WD40 under the grip. It slid right off without difficulty. The ridge on the end of the throttle tube wasn't a probem once the WD 40 lubed things up. Just remember to remove the grip from that inner flange on the throttle side or you'll have problems. The whole process is about 10 minutes at most.
By the way, I pulled mine off to install the symtecs.
SS
DL650K7
1985 RZ500
1986 NS400R HRC
1987 RG250
1987 TZR 250
1988 RGV 250
1989 RZ 350 F2
1990 RZ 350 N2
silverstrom is offline
post #6 of 12 Old 05-20-2008, 08:46 AM
A thin air nozzle works wonders for removing and installing grips. Just blow air under the grip and with a little fiddling they come right off.
johntm is offline
post #7 of 12 Old 05-21-2008, 10:46 AM Thread Starter
Xavier6162's Avatar
I don’t think I can produce enough wind to remove grips.
post #8 of 12 Old 05-21-2008, 12:04 PM
Heavy's Avatar
Originally Posted by Xavier6162 View Post
...So…how do you remove the stock grips without using an air compressor?...
hmmmmmmmm.
DL1000K6
Heavy is offline
post #9 of 12 Old 05-21-2008, 04:24 PM
Originally Posted by Heavy View Post
hmmmmmmmm.
Oops. Reading isn't my strong point.
johntm is offline
post #10 of 12 Old 05-22-2008, 09:33 AM
Don't be too hard on yourself, Johntm. After all, every man should own an air compressor. Someone had a quote from their father or grandfather that said, "you can't run a household without compressed air."
I agree.
bogey78
bogey78 is offline
