Scorpion installation tips wanted - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 07-11-2005, 08:17 PM Thread Starter
Before I install the Scorpion slip on, are there any tips or things to make the job easier? Is the stocker a double wall pipe to cut? can it be cut on the bike? pipecutter? Is the pipe heat shield re-used? pictures? anyway you can help to make the installation go smooth, let me know.TIA
Peace through ignorance!
MikeyA is offline
post #2 of 12 Old 07-12-2005, 11:56 PM
Gilk51's Avatar
I wrote this up on another forum, but here is the link: http://11109.rapidforum.com/topic=103478147103
I cut the pipe (single wall) with a brand new hack saw while on the bike. Leaned over the top to get a clean angle.
Did not reuse the upper heat shield.
.......Chuck
blue '04 DL-650
dark cherry '07 FJR
AARP member!
Gilk51 is offline
post #3 of 12 Old 07-19-2005, 09:45 AM
TheTwins's Avatar
Gilk how do you like your Scorpion - what is the sound like?
TheTwins is offline
post #4 of 12 Old 07-19-2005, 10:53 PM
Gilk51's Avatar
I like it - definitely louder but a good, deep sound.
I have a short sound clip in the link in the previous post.
Several folks have said it sounds similar to a Staintune.
.......Chuck
blue '04 DL-650
dark cherry '07 FJR
AARP member!
Gilk51 is offline
post #5 of 12 Old 07-20-2005, 08:59 AM
TheTwins's Avatar
I like the write up you did there, very nice.
Man it is stupid how they place the logo, that just does not look right. How is the logo attached?
Are you happy with the setup overall?
TheTwins is offline
post #6 of 12 Old 07-20-2005, 09:24 AM
Gilk51's Avatar
Not sure how they attach the logo but I assume it cannot be moved. Didn't try it though when I got it mounted - too impatient to try it out.
I'm quite happy with it - I like being able to hear the exhaust & I don't think it is too loud. My only complaint is that it seems to have started a vibration about 5000 RPM that causes a buzzing noise somewhere in the front cowl. That may be just a coincidence, but seemed to appear after I added the new can.
.......Chuck
blue '04 DL-650
dark cherry '07 FJR
AARP member!
Gilk51 is offline
post #7 of 12 Old 07-20-2005, 01:13 PM
Isn't that logo just stuck on somehow? It sure would make the can look better if you could remove it....just IMO. Do you have SW-MoTech crash bars? Mine caused a vibration and just needed the connection piece at the front tightened up a bit.
RubberDown is offline
post #8 of 12 Old 07-20-2005, 03:10 PM
Gilk51's Avatar
Yeah, some like it on, some off. I like it on. Not sure how hard it would be to move it.
I have had the SW Motech bars for several months. I'll make sure everything is tight, but I think the new exhaust is resonating somehow - I didn't have the "buzz" before I changed to the Scorpion.
.......Chuck
blue '04 DL-650
dark cherry '07 FJR
AARP member!
Gilk51 is offline
post #9 of 12 Old 07-20-2005, 06:35 PM
BBurton "BigB"
I have seen several scorpion cans on bikes at bike night that had their decal removed. I had a scorpion exhaust on my Bandit 1200, I have nothing but good things to say about it. I will probably get the dual scorpion cans for my Strom when the time comes. I WILL take off the decals because I don't want them making contact with the strap, and I think that it looks dorky!! Take a heat gun or hairdryer to the decals and a plastic scraper to help lift a corner. They will come off, take some rubbing alcohol and some mothers stainless polish to the residue.
post #10 of 12 Old 07-21-2005, 12:46 AM
very cool. I think the Scorpion pipe would look excellent with the decals removed!
