Recommend a three wire splice - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 19 Old 10-29-2014, 05:53 PM Thread Starter
Ok. Another noob question- how do I splice 3 12 gauge wires (one from switch; two from pair of aux light) in the fairing area? Is there a unique connector?
Thanks again.
John
Jproaster is offline
post #2 of 19 Old 10-29-2014, 06:24 PM
SCraig's Avatar
(3) single butt connectors (male and female)
(1) 3-pole polarized connector (male and female)
(1) soldering iron and (3) pieces of heat-shrink tubing
Scott Craig - Nashville, TN
SCraig is offline
post #3 of 19 Old 10-29-2014, 09:00 PM Thread Starter
This might sound overly simple- why not just twist, apply proper size wire nut and wrap with some serious tape that wont come undone.
post #4 of 19 Old 10-29-2014, 10:15 PM
trapperdog's Avatar
Works well in a dry, enclosed, non mobile environment such as a switch box in a structure, not so well in any sort of vehicle.
'09 VEE
'07 HD SEUC
'09 ST1300P
'06 ST1300
trapperdog is offline
post #5 of 19 Old 10-29-2014, 10:17 PM Thread Starter
Yeah. I pondered that a few minutes after writing it.
post #6 of 19 Old 10-29-2014, 10:56 PM
trapperdog's Avatar
However, I'm sure I'm not the only one that's done just that as a somewhat temporary, on the road solution.
'09 VEE
'07 HD SEUC
'09 ST1300P
'06 ST1300
post #7 of 19 Old 10-30-2014, 12:17 AM
From personal experiences of making mistakes, I now use marine-grade components. Google the specific items you want and preface them with 'marine grade' and you'll find high-quality parts. I recently added an oil temp gauge/sensor project on my Wee using marine grade wiring/connectors/switches/relays and am confident that I will not have problems with moisture. BTW, the kit came from Motosens of Germany. It's a top-notch kit but the process of ordering and getting it to the USA was a total nightmare.
'92 Honda Z50R
'94 Kawasaki KLX250 modded to 340cc's
'00 Yamaha YZ426F
'94 Yamaha 125 scooter
'05 Vespa E4 scooter
'68 Vespa VBB scooter (restored)
'06 Wee
'03 Honda S2000 roadster
Boit4852 is offline
post #8 of 19 Old 10-30-2014, 01:24 PM
12 gauge? That would carry 30 amps in the relatively cool environment of a motorcycle. What amperage will it carry, and what wire size would be handier?
I ran a #12 negative wire from my battery post to the front of the bike to serve as a negative bus. I connect all the negatives from the various gadgets to this one bus wire.
post #9 of 19 Old 10-30-2014, 05:52 PM Thread Starter
Its actually for my 10 watt aux lamps. A friend gave the wire to me.
I know its overkill; do I need to use smaller gauge?
John
post #10 of 19 Old 10-30-2014, 05:57 PM
fortp's Avatar
It's overkill, yes, but there is no downside so you don't need to use smaller gauge.
fortp is offline
