Switched aux lights question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 10-28-2014, 08:45 PM Thread Starter
Im wiring in two 10 watt aux lights purchased from Adventuretech with a small lighted rocker switch. It seems that relays would be necessary.
Is that correct?
Thank you,
John
Jproaster is offline
post #2 of 6 Old 10-28-2014, 08:58 PM
The rocker switches at the Adventuretech web site are rated for 16 amps, more than enough for the lights by far which draw less than 1 amp each.
post #3 of 6 Old 10-28-2014, 09:18 PM Thread Starter
Well, there it is; another no-brainer I shouldve investigated for understanding.
Thanks greywolf. Im getting a quality education.
John
post #4 of 6 Old 10-29-2014, 11:37 AM Thread Starter
Rocker switch blade connections
Need a bit of clarification on the Adventuretech rocker switch- is the copper colored blade hot or to ground (negative in pC8)? I assume the middle blade is to the aux lights.
Thanks.
post #5 of 6 Old 10-29-2014, 12:21 PM
Check with Rick if you don't get a quick answer.
post #6 of 6 Old 10-29-2014, 12:49 PM Thread Starter
Youtube vid shows a similar switch with the brass as negative. My dual, weatherproof usb plug has the same color code- brass is negative and silver is positive.
