EB Relay kit this easy? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 10-28-2014, 06:31 PM Thread Starter
Just want to make sure Im getting this. To install headlight relay kit on '12 glee - unplug one lamp; plug the male socket from the kit into this socket.
- push one female socket from kit onto bulb.
- secure the other female socket and relays in safe place.
- run wire back to PC8.
Is it this easy? Or am I missing something?
Thanks,
John
Jproaster is offline
post #2 of 7 Old 10-28-2014, 06:50 PM
You unplug both stock lamps, plug the male plug from the kit into one of the stock sockets and tape over the other one, plug the two female sockets from the kit into the lamps, secure any loose items with the relay wires pointing down and run the red and black wires to the PC8.
post #3 of 7 Old 10-28-2014, 07:08 PM Thread Starter
Thank you sir. Your explanation is right on my level- simple.
John
post #4 of 7 Old 10-29-2014, 11:56 AM
bmwlarry's Avatar
Why - relay wires pointing down??
2013 Yamaha WR250R
2009 V-Strom 650DL-ABS
2015 Can Am Spyder RTS LTD SE6
2011 Can Am Spyder RT Limited - Sold
2010 Aspen Sentry Camping Trailer
2003 BMW K1200LT - Sold
2001 BMW K1200LT - Sold
2001 Honda 750 Nighthawk - Sold
1997 Honda 750 Nighthawk - Sold
bmwlarry is offline
post #5 of 7 Old 10-29-2014, 12:19 PM
There have been a few problems in the past with water seeping into the relays. Pointing any openings downward prevents that.
post #6 of 7 Old 10-29-2014, 12:20 PM
Vinegarjoe
eb relay
moisture?, limit rain from entering relay casing?
Vinegarjoe is offline
post #7 of 7 Old 10-29-2014, 05:51 PM
bmwlarry's Avatar
Installed mine an hour ago and install went just as easy as it said it would. I do wish I have bought the kit with the headlight cutout.
2013 Yamaha WR250R
bmwlarry is offline
