Stuck bolts - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 04-12-2008, 08:53 AM Thread Starter
Ted Bell's Avatar
Stuck bolts
I'm installing the Amotostuff skid plate and need to remove the two bolts holding on the sidestand. They are STUCK! Any thoughts on loosening them up. I thought about getting some PB Blaster or similar penetrating oil. Would that work? Or is there a better way?
Ted Bell is offline
post #2 of 6 Old 04-12-2008, 09:02 AM
mtlee's Avatar
Penetrating oils are always a good bet. I also used a long socket extension and a 2' piece of pipe over the socket wrench as added leverage. And had my son hold the bike while I piled on the torque.
I had him continue to hold the bike just off the sidestand while I did the rest of the install for that bracket - I didn't have a centerstand at the time.
'07 DL650 ABS
'04 Yamaha V-Star 650 Classic Silverado (gone)
'04 Yamaha TTR225
'03 BMW F650GS (wife's)
'92 Honda XR250L
'86 Honda VT500c (gone)
mtlee is offline
post #3 of 6 Old 04-12-2008, 09:14 AM
Heavy's Avatar
They probably have threadlocker on them. Some heat may make it much easier to loosen them.
DL1000K6
Heavy is offline
post #4 of 6 Old 04-12-2008, 09:55 AM
Yes. Heat is the key. They have the high strength locker on them.
post #5 of 6 Old 04-12-2008, 03:11 PM
silverstrom's Avatar
I used a pipe on the end of a 1/2 inch drive ratchet. Leverage is the key.
SS
DL650K7
1985 RZ500
1986 NS400R HRC
1987 RG250
1987 TZR 250
1988 RGV 250
1989 RZ 350 F2
1990 RZ 350 N2
silverstrom is offline
post #6 of 6 Old 04-12-2008, 03:31 PM
$Whatever$
Heavy-H's Avatar
For sure, those bolts are in real good....... I used half inch sized ratchet and extension. I to think heat is the answer......
06-DL1000 62000 miles....Sold...
Now 2012 Honda NC700X..37500 and counting...............FOR SALE
Now 2005 Suzuki Hayabusa..25000 and counting.......
Now 2018 Yamaha Super Tenere ES........
Heavy-H is offline
