Time to electrify - Part Two - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 10-07-2014, 06:59 PM Thread Starter
One thing at a time.
To install the Backoff modulator, I believe Im supposed to cut into the white wire w/ black stripe (not the gray wire) entering the brake light socket.
My question is where would you break into the hot wire and how would you make your connections? Im ready to try soldering, crimping, etc.
Thanks,
John
Jproaster is offline
post #2 of 5 Old 10-24-2014, 08:10 PM Thread Starter
Or posilocks.
post #3 of 5 Old 10-24-2014, 10:09 PM
bmwlarry's Avatar
Definitely use Positaps!! I would never "cut" into OEM harness!!
2013 Yamaha WR250R
2009 V-Strom 650DL-ABS
2015 Can Am Spyder RTS LTD SE6
2011 Can Am Spyder RT Limited - Sold
2010 Aspen Sentry Camping Trailer
2003 BMW K1200LT - Sold
2001 BMW K1200LT - Sold
2001 Honda 750 Nighthawk - Sold
1997 Honda 750 Nighthawk - Sold
bmwlarry is offline
post #4 of 5 Old 10-24-2014, 10:35 PM
It's a personal choice. I've cut back insulation and soldered to the stock harness on almost every bike I've owned. If you use a Posi-Tap, you cut through the insulation too.
post #5 of 5 Old 10-25-2014, 10:15 AM Thread Starter
Ok. Im almost ready; but, I want to solder and need to determine where in the wire. Ive disconnected the multi-wire socket and was musing on cutting midway to the brake light or somehow disconnect the white wire w/ black stripe from the socket.
Dont know how (or if its wise) to remove wire from multi-wire socket and practice western union, solder and heat shrink connections around modulator.
Or, will would what appears to be 14 ga stranded wire from the modulator fit into the socket in place of the hot wire and then only one wire to wire connection after the modulator?
Thanks for the education folks. This is good prep for wiring on my beater '87 wrangler that I just started up after bout 5 years of dormancy.
John
