Hand Guard extensions - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 2 Old 04-09-2008, 10:37 AM Thread Starter
DarrenVS's Avatar
Hi folks , has any one extended the stock K2 1000 hand guards similar to these, http://www.touratech.com/shops/008/p...fc60f09a87e91c I cant afford the nearly $200 for these aftermarket set, and would like to make my guards higher to protect the back of my hand from the cold air that comes over the top of the stockers
Darren
DarrenVS is offline
post #2 of 2 Old 07-20-2008, 05:33 AM
Darren
get some plastic,[I used a kiddies push along cart found at the tip] cut it to fit into the gap UNDER the guards level with the edge pop rivet them on it makes all the difference & you may not need to alter the top
SCOTTOWNER is offline
