Question - Stebel horn mount with Pat Walsh bracket - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 18 Old 04-08-2008, 08:22 PM Thread Starter
garandman's Avatar
the horn came with an extension on the casting, and a bolt. I got the Walsh bracket yesterday.
Is this how it mounts? His directions only show it mounted.
TIA
garandman is offline
post #2 of 18 Old 04-08-2008, 08:37 PM
Zygis's Avatar
I dont know, but if you can take some pics were you will install it and some write up.
Thanks Zygis
Zygis is offline
post #3 of 18 Old 04-08-2008, 08:46 PM
That's it. The U fits around the fairing frame member and the horn connection is how you show it. Keep the cylindrical part vertical.
post #4 of 18 Old 04-09-2008, 01:29 AM Thread Starter
garandman's Avatar
Thanks. Are you Pat Walsh, or is the name a coincidence?
post #5 of 18 Old 04-09-2008, 01:46 AM
I am not Pat Walsh.
post #6 of 18 Old 04-13-2008, 12:24 PM Thread Starter
garandman's Avatar
Frustration sets in. Hook up the bracket, Eastern Beaver harness, hit the button lights dim, but no horn!
And, I can't find my continuity tester to see if the relay is triiping and it's getting power. It was the last think I was going to do before I got it on the road. Grrrrrr.
post #7 of 18 Old 04-13-2008, 12:48 PM
You should hear the relay click. When I first tried mine, all I got was the relay click. I had no fuse in the fuse block. The lights should not dim. Try running a pair of wires directly from the horn to the battery for an instant to make sure the horn is working. Watch the polarity.
post #8 of 18 Old 04-13-2008, 01:03 PM
Heavy's Avatar
...Watch the polarity.
...and your ears.
DL1000K6
Heavy is offline
post #9 of 18 Old 04-14-2008, 11:26 PM Thread Starter
garandman's Avatar
Doh!
Checked the leads to the relay with a multimeter - 12V. Checked voltage to horn: 0 V.
Then, a revelation: the horn will not work, no matter how many times you press the starter button!
How I got it into my head to push the starter button when there was a red switch with a horn on it, right in front of my face, but that's what I did! Time to start making AARP jokes......
The Eastern Beaver harness makes it pretty foolproof, but I proved a Greater Fool.
post #10 of 18 Old 04-15-2008, 12:46 AM
The first time I tried it, I did the same thing. The second time I tried, I just got a relay click. I hadn't put a fuse in. You're not alone.
