What is the easiest way to stop footpeg rubbers from slipping? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 04-06-2008, 10:26 PM Thread Starter
Corkus's Avatar
My passenger pushes the passenger footpeg rubbers off their normal resting places. Today both were upside down at the end of a ride. We're going to lose one unless I secure them.
Tie wraps? Will those keep the rubber parts in place? Anyone done this? How did it work. I don't want the tie wraps damaging the rubber footrests.
Cory
07 DL650A
Pleasanton CA
Corkus is offline
post #2 of 10 Old 04-07-2008, 02:25 AM
Mine did the same thing originally. Put them back in the right position a couple times and they stayed put. No rhyme nor reason. Might be a good idea to fasten them down somehow................Ah here's a thought. Maybe the rubber is coated like a new tire and time will take care of it.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #3 of 10 Old 04-07-2008, 06:26 AM
SCraig's Avatar
If you can get them off something like weatherstripping adhesive for cars should work fine.
Scott Craig - Nashville, TN
SCraig is offline
post #4 of 10 Old 04-09-2008, 08:52 AM
mtlee's Avatar
I got this solution from another Stromtrooper awhile ago: run zipties through the little holes underneath the pad, and really cinch 'em down. Works great, no more passenger peg problems.
'07 DL650 ABS
'04 Yamaha V-Star 650 Classic Silverado (gone)
'04 Yamaha TTR225
'03 BMW F650GS (wife's)
'92 Honda XR250L
'86 Honda VT500c (gone)
mtlee is offline
post #5 of 10 Old 08-05-2008, 03:14 AM
The best way to fix footpeg issues is to replace both front and back with Pivot Pegz. I was fed up with feet slipping of stadard pegs. They are available and fantastic to ride with plus no passenger complaints on the rough stuff.
busa05 is offline
post #6 of 10 Old 08-05-2008, 03:51 AM
K1W1's Avatar
Same here. I can only assume that there is some sort of in built delayed foot peg rubber location mechanism. Very clever people those Japanese.
K1W1 is offline
post #7 of 10 Old 08-05-2008, 08:48 AM
Heavy's Avatar
You poor guys and these damn Wees. Always having to tweak them to get them to work properly.
DL1000K6
Heavy is offline
post #8 of 10 Old 08-06-2008, 04:41 PM
Hmmm. I seem to remember something about some one fine tuning your bike for you recently. lol.
05 / 650 in blue
75/Suzuki 125 RV
post #9 of 10 Old 08-07-2008, 09:13 AM
Heavy's Avatar
Fine tuning, not keeping pieces from falling off.
DL1000K6
Heavy is offline
post #10 of 10 Old 08-07-2008, 09:34 AM
I'd suggest that if you can, remove them, then apply some hand grip adhesive... The stuff that looks like black rubber cement that you use under the hand grips when installing them on the bars.
Pretty much anything will work... I've seen people use spray paint or hair spray. Both surfaces need to be clean, and whatever you use needs to start fluid (or nearly so) and dry tacky. Heck, I suspect grape jelly would work, but the bees around here love it, so I don't suggest using it.
gijoecam is offline
