I need a relay switch. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 27 Old 04-05-2008, 10:41 AM Thread Starter
WeThereYet's Avatar
I'm going to put a Blue Sea box in today and need to pick up a relay. I really want to pretend that I know what I'm talking about in the auto parts store, so what exactly am I asking for?
WeThereYet is offline
post #2 of 27 Old 04-05-2008, 12:14 PM
Koinz's Avatar
Just ask for a 12v automotive relay. 30 AMP rating. Here's a primer for you
http://www.teamrocs.com/technical/pa...lay_basics.htm
Koinz is offline
post #3 of 27 Old 04-05-2008, 01:58 PM
The usual service for such a device is as a horn relay.
post #4 of 27 Old 04-05-2008, 02:52 PM Thread Starter
WeThereYet's Avatar
Thanks guys. Appreciate it!
post #5 of 27 Old 04-05-2008, 10:55 PM
Heavy's Avatar
Aux lighting relays typically have high, 30 - 40, amp ratings.
DL1000K6
Heavy is offline
post #6 of 27 Old 04-06-2008, 08:19 AM
Relay Switch
This should make it a little easier.
RadioShack # 275-226 12V DC/30A SPST Automotive Relay. $6.79
Ragnagwar is offline
post #7 of 27 Old 04-06-2008, 08:37 AM
SCraig's Avatar
12-volt coil, single-pole, single-throw, normally open with contacts rated at least 30 amps. Or what any of the other guys said.
Scott Craig - Nashville, TN
SCraig is offline
post #8 of 27 Old 04-06-2008, 09:54 AM Thread Starter
WeThereYet's Avatar
Awesome. I'm going to get one this morning. I was searching some of the Blue Sea threads and you guys have done some pretty slick installs. It's too bad that we lose a fair bit of underseat storage.
post #9 of 27 Old 04-06-2008, 10:01 AM
SCraig's Avatar
There are places to put one that are more out of the way but you lose the convenience of replacing fuses easily. My fuse block is unswitched (intentionally) however one circuit does control a relay connected to a terminal strip for things that I do want switched. All of that is mounted behind the left side pod. I think one would also fit way back under the tail but you'd have to remove the rear fender to replace a fuse. It's a tradeoff between convenience and storage space.
FYI I've had one for my VFR since last summer and still have not found a single place large enough to mount it. Honda used virtually every cubic inch for something or other. Underseat storage is virtually non-existant and there is no space under the fairing that I've been able to find. Be glad Suzuki at least left room for one
SCraig is offline
post #10 of 27 Old 04-06-2008, 11:21 AM
Heavy's Avatar
Problem solved...and easy access too.
DL1000K6
Heavy is offline
