Installed Centerstand today! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 03-30-2008, 09:16 PM Thread Starter
jheverly's Avatar
Had my brother give me a hand, as I read that it works out better wth 2 people. Needless to say, all went well until it came time to attach the springs.
Good thing my brother is a strong bastard as they were a bitch. ended up using a pair of vice grips and pulling. Glad it's over, but really only took about 1/2 hour from start to finish.
jheverly is offline
post #2 of 9 Old 03-30-2008, 09:28 PM
Mr.Metal's Avatar
I actually installed my (Suzuki) center stand today as well. I would say it's mostly a one person job, and pretty straight forward. The springs were the only issue and tested me a bit. I ended up doing the rope trick, namely using the hook on the spring as a pulley, giving me leverage to pull it onto the stand. The big spring took some effort, but I finally got it.
Although it didn't call for it, I used blue loctite on all bolts. I figure it's probably a good idea.
2008 DL650 a.k.a. Road Warrior, member #16 of the Flat Black Club
2009 Aprilia Tuono 1000R a.k.a. Silver Thunder
Mr.Metal is offline
post #3 of 9 Old 04-04-2008, 07:20 PM
Installed an HB centerstand on my '08 Wee yesterday. I expected a lot of drama from the springs, but IMO it was fairly easy. If the stop/bumper is not installed, the stand can swing a little higher, bringing the two spring pegs closer together. Only had to stretch them about 1/8". First the inner spring,then the outer, using needle-nose vice grips. Lastly, installed the stop/bumper thing.
Sean
SeanF is offline
post #4 of 9 Old 04-08-2008, 11:49 PM
Which stand did you use. I hear some of these aftermarket stands tend to clank a bit when you hit a bump. Any problems yet? Thanks.
Flat Black Club #28 - IBA #37257 - PGR
08' V-Strom 07' GXSR750
05' YZ125 04' TRX400
02' CRF450 02' SV 650
96' XR50 74' CL 360
74' XR75 72' CB750
SPCN HD FXR All in good fun!
Gowiththeflow61 is offline
post #5 of 9 Old 04-09-2008, 12:21 AM
Byronw's Avatar
The OEM stand is one of the first things I added to mine when I bought it a couple months ago, does anybody know, should we use lock tight on the bolts to prevent vibrating loose?
Byronw is online now
post #6 of 9 Old 04-09-2008, 01:29 PM
I doubt you could go wrong using a dab of Loctite Blue on any fastener on any motorcycle. Especially on a vibey single or twin.
SeanF is offline
post #7 of 9 Old 07-07-2008, 12:39 AM
Just installed the Suzuki center stand on my DL650 this evening. I was thinking 'this is a piece of cake' until I got to the springs. I'll second what was said above - getting the springs on was a battle. Luckily I was able to use some junk parts in my garage to rig up a spring puller gadget like the instructions showed. I don't think I could have got them on there with pliers.
I didn't use loktite on the bolts, but I plan to check on them every once in a while.
green guy is offline
post #8 of 9 Old 07-07-2008, 12:47 AM
The shoestring method pops them right on.
post #9 of 9 Old 07-07-2008, 10:41 AM
Poser's Avatar
I used a piece of string. It was ridiculously easy. The only flaw is that there is still a shred of stuck string under the spring. What to do...
2007 DL1000 - Givi Bags and Top Case - Madstad bracket with stock shield - Zumo 550 - Murphs brace - H&B center stand - Sargent seat - Switched relay electrical harness - Power Commander III USB - Highway pegs - Driver backrest
Poser is offline
