How do I raise passenger footpegs? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 03-29-2008, 09:37 AM Thread Starter
Corkus's Avatar
I have this fun and relaxing bike now and with it comes an immediate need to raise the passenger footpegs or my wife will not be able to ride for more than an hour without pretty serious sciatic back pain. If I raise the pegs, she'll be able to ride consecutive 10 hour days without trouble, and that's longer riding days than she enjoys.
Cosmetic considerations are minimal and if the footpegs can't fold after modifying them, that's ok. One inch higher footpegs would be much better. Two inches higher is probably ideal and three inches higher is probably better than one.
Both temporary and permenent suggestions are appreciated.
So how can I raise passenger footpegs on a Wee?
Cory
07 DL650A
Pleasanton CA
Corkus is offline
post #2 of 14 Old 03-29-2008, 09:51 AM
Take them to a machine shop and tell them what you need. It should be easy to weld up a higher bracket. A DIY type person could probably take out the stock peg, shape a block of aluminum to fit the stock bracket, and screw an aftermarket footpeg such as http://www.twistedthrottle.com/trade/productview/2699 to that. Such a task may be outside your comfort zone though.
post #3 of 14 Old 03-30-2008, 12:02 AM Thread Starter
Corkus's Avatar
This might end up looking like I'm building a bridge... I plan to use metal tubing to fashion a 4 leg lattice with one of the legs acting as a footpeg. Think of a 4 legged Tee Pee and you won't be far wrong :mrgreen:.
Turns out the pegs need to be WAAAAAAY higer. Much higher than I thought. The good thing is that there is no way this is going to look right so I can build a lattice that I think will work at least temporarily. Trust me, this is worth it if my wife can ride without pain. Rides are so much better if she is along.
(There are only 3 attachment points in the photos but I'll also attach to the top of the footpeg tubing on both sides.)
I am going to leave the stock footpeg structures in place as the Givi bag mounts use them. I wouldn't be in much better shape if I took them off.
Right peg photo:
The new peg will have to be where the big red glob is and the attachment points might end up being where the squares are.
Legt peg photo:
I can do this. Good thing, 'cause I have to.
Hey if anyone has a better idea, I'll consider anything I can come up with as temporary.
Cory
07 DL650A
Pleasanton CA
Corkus is offline
post #4 of 14 Old 03-31-2008, 08:09 PM Thread Starter
Corkus's Avatar
My first ideas about higher footpegs will not work. Now I see why my passenger was getting back problems. The pegs have to go waaaaaaaay higher. I mean waaaaaaaaaay higher.
This is about the height and placement I need:
Back to the drawing board. This has got to happen one way or another.
Cory
07 DL650A
Pleasanton CA
Corkus is offline
post #5 of 14 Old 03-31-2008, 08:55 PM
just a thought...
what if you turned them upside down and switch sides?
would have to fab a new exhaust mount and figure out how to keep the rack installed
Bitter Born is offline
post #6 of 14 Old 03-31-2008, 09:47 PM Thread Starter
Corkus's Avatar
Originally Posted by Bitter Born View Post
just a thought...
This was my first thought, but the brackets are different by quite a bit because of the exhaust on one side. Also the bolts that hold the brackets to the bike do not attach to the bike directly opposite each other.
Further measurements and the magic number looks like 5", that is down from 6.5" yesterday. That's good, 5" looks like a much easier number. 5" doesn't go past the top of the brackets, it lands nicely alongside the top of the stock brackets.
Would it be possible to have some metal welded onto the existing brackets to form a proper base and weld an aftermarket footpeg permanently to the base? That looks doable to my eye. Anything obvious I don't understand here? (I have no idea what kind of metals would be involved in the welding or if the welded base metal itself should be the new footpeg.)
Cory
07 DL650A
Pleasanton CA
Corkus is offline
post #7 of 14 Old 04-02-2008, 05:05 AM
fredellarby's Avatar
You apparently have a mounting point from the original footrest mounts right beside where you want to mount the new pegs. Could you use these to mount new pegs similar to frame sliders.
Either find a long slider or use a long heavy bolt, cover it with rubber hose and screw it straight in?
{$.02}
Fred
I'm not always sarcastic.
Sometimes I'm facetious.
Or ironic.....
If a tree falls in a forest and lands on a politician, even if you can't hear the tree or the screams, I'll bet you'd at least hear the applause.
Paul Tindale
fredellarby is offline
post #8 of 14 Old 04-02-2008, 10:56 AM
rcacs's Avatar
Exactally what I did mate. Using the top bolt of the mount, I bought some folding footpegs that are rubber covered (intended for cruise pegs) and bought a bolt about 1.5" longer. They are perfect for my daughter when she comes along as a passenger.
I left the stock pass pegs in place for when my wife comes along.
Cheers!
rcacs is offline
post #9 of 14 Old 04-02-2008, 02:22 PM Thread Starter
Corkus's Avatar
{$.02}
and...
Cheers!
Now this sounds like a winner! Thanks for the idea gentlemen.
racs, you wouldn't by any chance have a link or a part number to the footpegs you are using?
I am going to start looking for bolts today.
Cory
07 DL650A
Pleasanton CA
Corkus is offline
post #10 of 14 Old 04-02-2008, 02:39 PM
rcacs's Avatar
Sorry, I dont. I had these lying around from one of my old bikes. If I recall, they were actually Yamaha parts, rear footpegs for a very old DT175 or something.
Check your local dealer for aftermarket folding pegs.
Cheers!
rcacs is offline
